Glare shield - Leather or vinyl?
After painting flat black, I'm not so crazy about the look/finish. Now considering gluing vinyl (flat black - I have a really nice piece). Any ideas on how this will hold up versus leather?? Ideas?
Thanks! |
glare shield
When I ordered my Aviator interior Leather package from CAD, I ordered the leather glare shield at that time (delivery date, end of July?). Just thought that a shield of some kind would made the panel a little easier to view. How long will it last over vinyl? I have no idea. I think it should last as long as vinyl. That being said, I'll have my plane in a hanger, so excess exposure will be minimal. Regards.
I used carpet...
For what its worth, I used carpet in my Kitfox and will likely use it again in the -8 for both the glareshield and floor (I also covered the forward sidewalls in the Kitfox). You can find carpet with about 1/8-3/16" nap in auto electronics stores and some auto stores. This carpet is used for interiors and covering speakers.
The carpet comes in many colors, is easy to put down with velcro, tape or glue and is cheap; and holds up very well. It also is pretty much a surface that you can lay stuff on and it won't simply slide off (probably won't hold your glasses during that wifferdill though). My 2 cents worth, H |
Synthetic Material
Contact Classic Aero Designs. They have this stuff called (I think) Columbia and it won't shrink or curl in the sun. Glue it down. Looks and feels like leather but won't crack either.
I used it and although not flying yet, looks really good. Get some of the edge pinch stuff too. |
Leather or vinyl
I think leather is a better choice. Seems to me that there is some issue with vinyl in the sun and gasses it releases and it's affect on the plexi.
Might check with your windshield supplier or Vans. |
I would shoot for the leather--about the same weight and nice smell compared to vinyl. Also, if properly cared for (meaning NO silicones, Armour All, etc) it will last just about forever. Well, a long time anyway. I did my panel in leather and love it. You can always tell 'em it cut your noise level by .002 Db!
Bob Kelly |
Neither
I bought a bolt of black loop Velcro and used that. It feels like velvet and works great to hold my GPS and XM antennas, pencils and anything else I put the hook Velcro on.
Glare Shield
Personally, I went for light weight and did a low gloss, not quite flat black. (I think it may have been called "Satin".) Looked much better than flat black. Can't remember the brand, but it worked for me. Got if from the Hardware Store in a rattle can.
Myflat black painted glareshield gets almost hot to the touch in direct sunlight. It seems the velcro idea would really reduce the heat buildup. How would the other ideas affect that?
| All times are GMT -6. The time now is 04:05 AM. |
