VAF Forums
-   RV Building Tips/Techniques (https://vansairforce.net/community/forumdisplay.php?f=74)
-   -   Tip: Canopy Cutting Suit (https://vansairforce.net/community/showthread.php?t=31549)
David_Nelson 06-30-2008 07:52 AM
I cut my canopy this weekend and like others have written, the process makes a huge mess as the shavings and dust seem to stick to everything! While at Lowes, I bought a polypropylene painters suit for $7. It's a coverall style of clothing so it's easy to put on, take off, and shake out, and it's not too terribly hot.
scard 06-30-2008 09:25 AM
Awww, come on, of course we wanted to see you with it and all of your other "protection gear" ON! :). A picture of the package is all we get? Glad you got it cut. It isn't nearly as bad as we all fear the first time around is it?
David_Nelson 06-30-2008 11:13 AM
Pictures?
Oh, trust me, there are some pictures. Strictly for "FAA" purposes. Yep, the whole process was pretty painless. Slow-n-easy was the rule and of course plenty of hot weather.
Webb 06-30-2008 11:58 AM
Its the....
You should call it the fiberglass suit..
Plexi doesn't hold a candle to fiberglass when it comes to knowing you cut it that afternoon
David_Nelson 06-30-2008 12:58 PM
Hi Webb,
Oh good grief, I forgot about the fiberglass! <sigh> Guess I'll hang on to "the suit".
You mean to tell me that the cowling, fairings, rudder bottom, and wing tips just don't snap into place?! :D
Take care,
Webb 06-30-2008 02:37 PM
It Snaps
Originally Posted by David_Nelson (Post 235297)
Hi Webb,
Take care,
It snaps right into place....after you cut it...after sand it....after you trim it....after you fit it...after you repeat all above......
Best trick I found for plexiglass was to have someone hold a shop vac by the cutter. If no one around, a potent fan at your back keeps you out of the worst of it (outside of course).
