suggestion for config change
I didn't find any other better forum at VAF to post this, so i thought i'd post it here.
I was on the AOPA forum, and some users have a cool map of where they've flown as part of their signature. That feature is apparently not available on this site. Under User CP and signature, the permissions are set thusly: Can Upload Images for Signature No Perhaps you could consider changing that config parameter? BTW, this is the sort of map I am referring to: ![]() and to create one, just go to http://www.epgsoft.com/VisitedStatesMap/ |
I have a Google Map that I use to track professional/personal and aviation visits. I use a different pushpin for each one
| All times are GMT -6. The time now is 04:45 AM. |
