ECI exp (AE) fuel injection with Van's F.I. (AFP) pump
hi,
has anyone installed the new eci exp (airmotive engineering) fuel injection system together with an airflow performance fuel pump package? we ordered the afp pump early on and installed it, only decided on the fuel injection about half a year ago. now the installation manual for the eci injection calls for dual speed pumps, excerpt: Quote:
what have other builders done? if possible, we'd like to stick with the AFP pump and also keep it simple by not plumbing an additional facet pump or the like into the system. thanks for hints! kind regards, bernie |
Two speed boost pump
[quote=flyvans.com;224417]hi,
according to Don at AFP their pump can be throttled. They however don't have a voltage vs speed vs fuel pressure table, has anyone experimented/tested on that? That's not quite true. What I said is that it may be possible to change the pressure by changing the speed of the motor, but we have never tried it, and you would have to have a DC motor speed controller not just a resistor to vary the speed. This can also be done with an solenoid valve and and additional pressure relief valve. But then again I don't know how accurate you have to hold the pressures to keep the ECI FI happy. It may be best to just suck it up and get the two speed boost pump ECI recommends. Don |
sorry don, if i misquoted you in this case...
of course, it wouldn't be exactly turn-key, was thinking about a dc-dc converter once we know the right values/settings, resistor producing too much heat... i also contacted eci and we'll see what their take is on the subject. thought i would shout out to the crowd and see wheter somebody else has been there, done that. will also get in touch with mahlon and see what mattituck uses on their test-cell / their experiences so far... kind regards, bernie |
I'm Interested In What You Find Out
Bernie,
I am also planning on the ECI EXP fuel injection (vertical induction) system in my RV-7 so I am interested in what you find out. I installed dual fuel pumps. The AFP high pressure fuel pump is installed in its normal position in front of the spar carry-thru, and a standard Facet low pressure fuel pump is installed downline (in roughly the position called out in the plans on the inside of the firewall). I also installed a bypass valve across the Facet pump, so each pump has its own bypass valve. According to the Airmotive Engineering documentation, this should work well. As I don't even have my engine yet, I'll have plenty of time to change the set up if I find out differently. |
here's the very informative response from mahlon @ mattituck:
and the response from eci (airmotive engineering):
so in essence, this leaves me even a bit more puzzled than before.
findings:
so this leaves basically three options:
wanting to run mogas one day / minimizing chances for vapour lock also comes into play. i will keep in touch with AE and post about further info. rgds, bernie |
update
hi
received some more details from ae: Quote:
rgds bernie |
well, finally, probably my last post on the subject ;-)
no low boost pump setting will be wired nor will there be a secondary pump after the latest exchange. here are my most recent questions, i had bobby at AE answer: Quote:
rgds, bernie |
| All times are GMT -6. The time now is 04:37 AM. |
