VAF Forums
-   Nosewheel vs. Tailwheel (https://vansairforce.net/community/forumdisplay.php?f=56)
-   -   The debate is resolved (https://vansairforce.net/community/showthread.php?t=30089)
mgomez 05-16-2008 04:49 PM
Bombardier has figured out how to resolve the nosegear vs tailwheel debate:
http://www.flickr.com/photos/21003395@N08/2483330336
Martin
joe gremlin 05-16-2008 05:21 PM
The unigear is on the wrong end. :D
Sorry, I couldn't resist.
n5lp 05-16-2008 05:40 PM
Both at once.
TODR the other day mentioned that he has been flying an ASK-21 glider. Like many modern two-seat gliders the ASK-21 normally has both a nose wheel and a tail wheel and a main gear. I'm not sure about the 21 but a lot of these two seaters can use all three wheels on one flight, depending on loading. http://en.wikipedia.org/wiki/Schleicher_ASK_21
My dorky little PW-5 has a main gear, nose wheel, tail wheel, left tip wheel and right tip wheel, for a total of five. Got the bases pretty much covered.
az_gila 05-16-2008 06:27 PM
All corners covered...
...and if you don't balance correctly on the big one, you always have a wheel to fall on, no matter which end of the glider drops....:)
gil A - with a Mini-Nimbus with only two wheels (and I had to add the tail wheel...:)...) -- skids on the tips, and an expensive fiberglas repair if you use the nose...
n5lp 05-16-2008 06:35 PM
Originally Posted by az_gila (Post 223680)
...with a Mini-Nimbus with only two wheels (and I had to add the tail wheel...:)...
Nice glider Gil, I had a C model for quite a while. I put a roller-blade wheel on the tail. Great improvement!
mgomez 05-16-2008 07:54 PM
I love that!
N941WR 05-16-2008 08:42 PM
I didn't know Europa came out with a bigger model.
