Confidence level increasing in Dynon
As a product of old-style flying, I kept some steam gages as backups when I installed my Dynon D-100. Today I watched in amazement as I had an avionics tech with a $30,000 test set renew my 6A pitot static/xponder/altimeter/IFR Cert.
My calibrated backup steam-gage altimeter was no where as close as the Dynon! From -1,000 to 20,000' that Dynon was within a few feet of perfect and the airspeed was more accurate than my steam-gage airspeed indicator. My confidence level has hit a new high after watching the two-hour test process. |
Same for me. My $700 United TSO'd altimeter was no where near as accurate or consistent as the D100 in the test from SL to 20,000 feet.
I've been extremely impressed with the EFIS altimeters I have seen tested - much better than any mechnical altimeter I've ever had.
Romance of the old days aside, digital systems are the way to go!
Warm-up time?
Has anyone else noticed this with the D-10A? It also prevents me from using the Dynon feature that remembers the altitude when you turn it off and automatically adjusts the altimeter setting for pressure changes when you turn it back on. |
I agree. Dynons seems to be rock solid, easy to use, and pretty in the panel.
EFIS altimeters in general
Many EFIS altimeters are based on silicon diaphram sensors and many use types like the Freescale MPX4115 or a similar device from Honeywell.
They are pretty accurate out of the box and have good temperature behaviour. They are also very linear over their pressure range with maximum deviations (uncalibrated) well below 1% of reading or range typical. It is very difficult to make a mechanical instrument to match the repeatability, robustness and long life expectancy of these sensors. Most EFIS manufacturers will get accuracies within 30ft below 5000 ft with slightly larger errors above this and it is largely a matter of how accurate the manufactures calibration reference is. You will find a slight spread between sensors with respect to temperature behaviour - some are spot on, others have a slight drift. Generally, if enough money is available to pay for calibration time, even residual errors can be calibrated out. When we started out many years ago we bought an expensive pressure reference system and a mercury manometer (just in case) only to find that the sensors we where using where in fact better than the types used in the calibration reference ! Up to today our very first instrument off the line (Stratomaster Flight, serial number FA01) is still used as crosscheck reference during calibration of our current instruments (we use 2 references so we don't get caught out by a faulty reference). When it comes to airspeed measurements, particular at very low speeds (low pressure measurement), the electronic sensor is so far ahead it's not even funny anymore. Simply no contest. Rainier CEO MGL Avionics |
Geoff, you're not alone..I know one more Dynon user with same behavior... I have to say, I've never heard of altimeter "warm-up" in an EFIS so to me that doesn't sound right.
Dynon rock solid
I love both my Dynon units...I love them even better when they get totally confused when I wring the airplane out and it then says...Horizon recovering..and Boink there it is fat dumb and happy.
I would never treat a mechanical gyro they way i do thee things.. Frank |
I do know that the Dynon instructions for calibrating the compass (internal or external) specifically require a 10-15 minute warm-up time on the unit. Not sure why that is, though... Over all I'm extremely happy with the D-10A. The only thing I don't like is that you can't display the real-time wind vector after entering the OAT manually -- you are required to have the Dynon OAT probe (and the remote compass) to get the wind vector. Since you can use some other temperature-related features by entering the OAT manually, I think you should have the option of using the wind vector too. I suggested this to Dynon, and they said they'd consider it in a future release. |
| All times are GMT -6. The time now is 05:39 PM. |
