VAF Forums
-   RV Building Tips/Techniques (https://vansairforce.net/community/forumdisplay.php?f=74)
-   -   Tip: Alternator safety wire (https://vansairforce.net/community/showthread.php?t=29634)
mburch 05-03-2008 11:46 AM
I was inspired by this post from George to invent what I think is a slightly clever way to secure the safety wire for the two bolts on the alternator tension arm.
I drilled a couple of #30 holes in the meaty part of the arm, and grabbed some #4 steel tinnerman washers and 1/8" steel pop rivets:
When riveted to the arm, the washer sits just high enough above the surface to capture a loop of safety wire. Now the wire bears on the steel pop rivet stem, and doesn't dig a groove in the alternator arm:
The finished product:
happy building,
mcb
Ironflight 05-03-2008 06:08 PM
Clever Matt - I like it! Next time I am in there, I think I'll make your little mod....I've never been satisfied with my safety wiring in this area!
Paul
Geico266 05-03-2008 07:32 PM
Well done.
Captain_John 05-03-2008 07:45 PM
Very elegant!
I like it!
Thanks Matt and George!
:cool: CJ
panhandler1956 05-04-2008 06:37 AM
Thanks for sharing
Great tip and good photos!
I'll file that one away for my FWF assembly.
Regards,
mburch 05-04-2008 06:51 AM
Thanks guys. For those who asked, the #4 steel tinnermans come from GAHCo - look for "#4 CSW, SS SH". I used a bunch of them on my canopy to keep the rivets from pulling through the fiberglass skirts. You do have to ream them out very slightly to fit the rivet through, but it's easy enough to do.
The blind rivets are CCPQ-44's, I think. The rivet selection is not critical, I just happen to have a ton of these left over from a previous project.
mcb
BillL 04-05-2016 06:06 PM
Warning, Zombie Thread Revival
Great idea for safety wiring. I did not have the #4 tinnermans, but did have some non-aviation stainless 1/8" rivets. I took a 1/8" washer and cut a slot, set the rivet, then removed the horseshoe washer. It worked GREAT!! My alternator is installed and the safety wire method looks great. Thanks Matt.
Don't shy away from an oldie, but goodie, thread! Timeless information.
