Oxygen Source - Lawrenceville, GA
I am in the process of installing a oxygen tank in my RV8 and am looking for a source of oxygen in Lawerenceville GA area.
I have a transfilling hose and one local welding shop quoted me a tank rental at 39 cents\day ($142\year) plus $26 to swap the tanks. I am thinking I would need two 80 cu-ft tanks to make the transfilling process practical. Should I buy some tanks and tranfill myself or is their a convienent scuba\medical store close by that is cost efficient? Am interested in what other locals are doing? Thanks Steve |
OXY
The maintenance facility to the west of the resturant on the South side of the field serviced my bottle for $20.00 last fall. Can't remember the business name though.
Hope this helps get you started till you find a better solution. |
I go to this welding supply shop near by to fill my large tank Steve.
http://www.airgas.com/ Bout a mile from the airport. http://maps.google.com/maps?ie=UTF8&...7&z=15&iwloc=B What I dont know is if they fill or not. I do tank swaps cause I own mine. I suspect they do. And they are cheap cheap cheap. |
Mike - Did you buy your refilling tanks locally? If so where
Thanks Steve Quote:
same place.
I bought one tank, and I just exchange it. I believe this is common practice amongst welders but I cant be sure. You bring em a tank, and you pick up a different one. While you buy the first tank, in the exchange process, you will probably never see that particular tank again. |
| All times are GMT -6. The time now is 08:09 PM. |
