VAF Forums
-   RV Building Tips/Techniques (https://vansairforce.net/community/forumdisplay.php?f=74)
-   -   Tip: Removing the handle from the stock fuel valve (https://vansairforce.net/community/showthread.php?t=29440)
Brantel 04-27-2008 08:31 AM
To prevent breaking the internals on your stock fuel valve, do not pull up on the handle very hard as this can break the nylon inside where the pin goes thru it and the shaft. :eek:
Instead loosen the screw a few turns and then use your cleco pliers to pop the handle right off. :D Stick the forks of the pliers under the lever and the socket of the pliers over the screw and squeeze.
