Spin testing observations - feedback requested
Hi,
Last week I did some spin testing on VII (RV 7A - large rudder) as part of the later stages of flight testing. I've been comfortable with the stall / power on / off / bank etc for a while and slowly worked up with 1/2 turn, 1 turn, 1.5 turn and 2 turn spins. First observation which I was expecting from the reading was 2 turns starts to really wind up - quite 'exciting' ;). That said it all did what it was meant to and responded nicely to standard recovery. A short video of the stalls / spins - http://www.youtube.com/watch?v=xVMWKFI9gb4 - excuse the lack of music / my chatting - it was for flight testing! I'm initiating with full aft elevator and full left boot at 60 kts in a slight nose up attitude. 1 turn seems to be about 400 feet. Yesterday I also did some more .5 and 1 turn with more foreward CofG ( 1428lbs @ 81") . It seems to my limited experience to swing through even further to quite an 'inverted' position - is this others experiece too? The swing through is more than I was expecting. As an alternative - if you have google earth installed ( http://earth.google.com ) a mini animation clip at 10msec is available at http://www.rvproject.gen.nz/kml/ZK-VII_2turn_spin.kmz - this shows nicely the attitude changes. Hope to get feedback from others experience - particually the initial 'inverted / on the back' attitude before I start moving the CofG further aft towards the aeros aft limit. Regards, Carl |
Based on the video, looks like you had enough after the 2nd turn.
How did the GRT avionics hold up during the spins? Any problems? Jim |
Hi Carl,
I'm no great expert but I do practice spins every couple of months (around oil change time preferably). From looking at your video your spins look identical to the view I'm used to seeing from my 7A (with the later rudder). Looks like you are doing a good job on your flight testing. |
GRT good
2 Turns - enough for one day - then went onto some loops and rolls :) |
Spins
Carl |
Looking Good!
Hi Carl,
Your spins look a lot like what I saw in the -8 during my own phase 1 testing - I haven's spun a -7 myself, but they seem pretty close from your video. Your program looks like it is progressing well, and should be an example for those folks who think that Phase 1 is "flying the same hour 40 times". The combination of GRT-recorded data, video, and voice recording sure makes it a lot easier to build a database than having to do it with pencil and paper, doesn't it?! I wish I'd thought of mounting a camera like that during my own Phase 1, but the video camera I had at the time would have taken some engineering time - if I'd had the little SD400 I have now with a big memory card, it would have been a piece of cake, and I'd recommend that to anyone - do you have a picture of your camera mount you could share? I'd like to have that for my Flight Advisor files. Congrats, and keep up the good work! Paul |
Questions
The GRTDecode stuff has been great (when I remember to start and stop it!), hopefully GRT will get the auto start / stop logging working soon. GRTDecode needs quite a bit of work, I've started with development of a proper GUI and the Google earth representation will improve in the next version. I'm currently using quite a lot of Excel charting / plotting functions, it would be nice to integrate that too - but difficult to make flexible enough for everyone. I'd also like to be able to keep a continous timeline of the plane, rather than just a single flight. The FADEC engine log is great - provides complete engine history from hour zero and has helped in the diagnostic process more than once. Biggest risk for us is too much information and worrying about 'normal' things...... I still find logging on a knee pad the first cut of the information - things like % power, DA and TAS aren't trival to re-calculate and it is simpler to record with pen/paper and voice on video. Quote:
![]() The photo above shows the tray/bracket it sits in - there is a location peg on the bottom and a screw upwards to hold the camera down. The base pivots at the back and fixes at the front which meant the sky / panel can be adjusted. It works quite well even with two people. I'm using just a basic Canon DV camera, but seems to hold up to at least 4 G :D. The 43 hours of flight testing, most have been video'd - about 400GB of raw footage. I'll try to get a photo of it with a camera / more details for you when I'm next down 'big shed'. Regards, Carl |
Nice video and thanks for taking the time to create, edit, and share.
What kind of speeds are you seeing in the recovery?? Thanks |
Speeds
Not sure I'd want to spin power on! :eek: I'm guessing right boot might be a little more exciting too.... Carl |
My recent stuff has just to stay current in case I botch my beginner acro moves. |
| All times are GMT -6. The time now is 04:43 AM. |
