VAF Forums
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   LSE Plasma II w/Direct Crank and AF3500 (https://vansairforce.net/community/showthread.php?t=29271)
dhall_polo 04-22-2008 02:42 AM
Looking for information/support on LSE inputs for engine monitoring.
The Plasma II w/Direct Crank has some outputs for tach and mp. Are these supported directly by AF3500/EIS? Any input on using these versus stock AFS rpm and mp sensors?
From the LS website:
RPM Output
Included in the options of the PLASMA II PLUS is a built in analog tachometer output. This provides RPM information for a mV meter. 0.3 volts represent 3,000 RPM, .0 v = 0 RPM.*
Absolute Manifold Pressure Output
The manifold pressure display option uses the calibrated and temp compensated manifold pressure information of the PLASMA CDI and allows it to be displayed on a digital mV meter.*
