VAF Forums
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   10 to 1 compression and electronic ign? (https://vansairforce.net/community/showthread.php?t=29111)
cujet 04-17-2008 07:16 AM
My good friend runs a Velocity with the angle valve Lyc and 10 to 1 compression. He also runs dual L/S Ign's. With the base timing set at 18 degrees. Other than one cracked cylinder (early on, the cyl was welded), he has had no problems.
Now, I hear all sorts horror stories from all manner of people. Including some engine builders at Sun N Fun. The Elec ign folks all say "no problem" the engine builders are all over the map on this one. Including dire warnings of "blowing a cylinder off".
However, I am currently operating an (exhibition experimental) Extra 300L with a angle valve 10/1 compression BPE engine with no problems. I would like to install an electronic ignition to provide better starting and more efficient cruise.
The aircraft is equipped with EFIS with EGT/CHT.
My specific question is whether anyone here has used electronic ignition with advance on a 10/1 Lycoming angle valve? If so, what were your results?
Thanks!
Franklin
gmcjetpilot 04-17-2008 09:28 AM
"Stories"
Originally Posted by cujet (Post 215817)
My good friend runs a Velocity with the angle valve Lyc and 10 to 1 compression. He also runs dual L/S Ign's. With the base timing set at 18 degrees. Other than one cracked cylinder, he has had no problems.
Thanks!
Franklin
The KEY word in your comments is "Stories". For some reason in the aviation world "stories" become urban legend and myth. Now not saying that high compression and timing advance don't add up to more pressure or temp in the cylinders. I can say just out of hand the combo of higher compression and even timing advance means less detonation margin.
The thing about myths is there is always a thread of truth, but often the total story is "busted". Most EI including LS have very conservative advance schedules or mapping, so the pressures are lower, advance is safe, even with high compression, especially with a very conservative 18 degree base timing.
Cylinder crack? It could be just a defect in the cylinder? It could be a weak point that if at 8.5:1 CR and mags would have lasted longer or forever.
The key is so much in the hands of your friend and how he manages his engine. First does he watch his Oil and Cyl temps like a hawk. Does he run it around well above 75% power mostly. Does he ever lean above 75% power (personally I would make it 70%). Does he run it hard and hot and than chops the throttle. Does he do long idle descents. I am not alluding to shock cooling since that is somewhat of an urban legend, but normally it is bad form to do the above for many other reasons besides possibly cracking cylinders.
A cracked cylinder is a hard call. Piston, ring or valve issues (damage, melting) could be a sign of detonation. A cylinder crack? How many hours on the Jug? If its low time it could be a defect. If it was a 2nd time around rebuild it could just be metal fatigue.
Personally I built my dual LS O-360 with stock compression for reliability. You can expect an engine you milk more power out of than stock to not make TBO. A little compression bump tends to be more efficient fuel econ wise but 10.0:1 CR is getting a little high. My advice, replace the jug and go fly.
SHOULD YOU GO TO EI WITH YOUR HC ANGLE VALVE?
No, is my gut feel. EI really pays most dividend at high altitude (low power) cruise. It should like you are not just boring straight and level holes in the sky. You're right, starting should be improved with EI, but why is it hard to start? The money and expense to install EI may not be worth it? You can turn the advance off and just run it straight Zero degree for start and fixed timing after. The hotter spark does pay dividends for both starting and flying, adding a little power. If you go that way, I would just need one unit. I like the LS more for the "ultimate" ignition, especially for an all out acro plane. The first EI gives 90% of the benefit efficiency wise, the second is just the last 1% or 2%. EI is at its best advantage for lower power cruise econ (where the timing advance kicks in). For starting benefit only one EI is needed. Magnetos are not totally old fashion or with out merit. If you put EI on and "de-tune" you timing, you lower the HP gain you got from the compression. For an acro plane I'm tempted to say leave the mags and try to figure out a way to improve starting. I know SkyTec has a new top-O-line geared starter that has more crank power but uses much less electrical power. Bottom line the more power you squeeze out of an engine, logically there may be some loss in TBO. For racers and competition acro, max TBO is not an issue.
elippse 04-17-2008 09:46 AM
Racers at Reno with much more than 10:1 on their 360s have had no problems with LSE. LSE has three different timing curves; one for normal CR, one for high compression, and one for turbo-charged. In each case, the WOT advance is always the factory-recommended value and no more. No engines with LSE at Reno have had a blown cylinder, but many with magnetos have. Klaus has taken a very conservative, well researched approach to his timing curve to stay away from detonation and the often resulting pre-ignition. He's in business, right? He doesn't want to get a bad reputation. Too often when someone has an engine problem and they have an EI of any sort the first thing suspect is the EI, and when they speak with their mechanics there are often those nearby who overhear the brain-storming of what may be the problem who latch on to any mention of the EI and are quick to report it. It's somewhat like what happens when people speculate about the cause of an accident before the final NTSB report. Lots of smoke!
elippse 04-17-2008 10:01 AM
I have two Plasma Is on my 9.7:1 O-235 with about 300 hours. A national aerobatic champ has LSE on her aerobatic plane and her homebuilt.
cujet 04-17-2008 10:37 AM
Thanks for the various replies. The goal is more efficient high altitude cruise, better starting.
With all the fuel burn claims, I wonder if the big EE gains are from advanced timing on a low compression engine. The high compression Lyc runs quite well and is well balanced. I currently run 22 degrees base timing (2 mags).
It could be that the folks running EE on 10-1 engines simply run no advance. In the case of the Velocity, he runs advance and is getting fantastic fuel economy. Mostly due to aerodynamics, I am sure.
Franklin
elippse 04-17-2008 12:42 PM
It doesn't matter whether it's high compression or turboed, with the LS there is still advance with decreasing MAP and increased rpm. I typically get 33-35 mpg at 11,500 to 12,500 with my O-235 at about 200 mph TAS. I'm running about 32 deg advance at that point.
Rocketboy 04-17-2008 05:07 PM
Hey Dilbert...
First of all, we know your not really the infamous Franklin D Frateus. He vanishined years ago searching form TriOxyDiLithium acetate ore near the equater.
As for ignition, JUST DO IT. Put you Tesla device on your whiz-bang 9000 and go flying. Set the curve to Crazy Eddy and shift her into high blower.
Fly man FLY!!!
RP
breister 04-18-2008 08:34 AM
10:1 is not really that high - LSE recommends the same unit as for 8.5:1, but retards the recommended advance 5 degrees. I don't think they supply a different advance curve except for racing, but that may have changed from when I was shopping.
My LSE made a HUGE difference in my 10:1 IO-320, both for starting and in flight. Dropping the mag is almost unmeasureable; dropping the LSE is a greater drop than I experienced with dual mags and dropping one.
