RV-10 Cowl Hinge Pins
I'm working on the cowl hinges now and wonder what others have done while fitting the aft top hinge for drilling? I can't get the 1/8 aluminum pins in without buckling them- a real bear. Did others just fit the 3/32 steel pins while drilling or will you get better alignment with the 1/8 ones?
Aft top hinge pins
Hi Ross,
Mine were a bear also. I ended up cutting the left and right sides in half, so I had 4 separate shorter pins that were a little easier to manage. The 3/32 steel pins fit MUCH better. cheers, Ron -10 almost done |
| All times are GMT -6. The time now is 01:31 PM. |
