VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   Finally Inexpensive Lighting (https://vansairforce.net/community/showthread.php?t=2874)
ww2planes 08-17-2005 09:54 PM
I recently located a company that sells position strobe combinations at a very good price. They are called Skybright. They have a great led product that will be on the ends of my wings. The package looks nice and should fit inside of the wingtip cutouts. For a position strobe unit without a rear facing white light he quoted $269.00. I challenge anyone to beat this price and get a package half as nice.
I have been talking with Rob Rollison of Skybright and he has been patient, timely and very polite. Check them out at the folowing sight.
http://www.airplanegear.com/skybright.htm
gmcjetpilot 08-17-2005 10:24 PM
Is there documentation it meets FARS
No matter if you are an experimental you must meet the FARS for coverage, color and intensity. The burden of proof is up to the builder and doubt a DAR would turn you down because it does not say Whelen. However.....
A couple of things: The strobe bulb is blocked by the fwd/aft Nav light shield/reflectors; even if mounted protruding from wing tip it does not look like it will have strobe coverage.
The NAV lights do not look like they can make the required coverage. I looked into making my own and this does not look like you would have the power in the obtuse direction.
Cheers George.
ww2planes 08-17-2005 10:58 PM
Brightness
I asked about this and Rob stated that they are actually brighter than what is required. As far as a strobe, you would have to nearly completely enclose one before it would be blocked. For many experimental aircraft the builder has options. This is a great one.
RV_7A 08-18-2005 10:08 AM
linky no workee :)
thallock 08-18-2005 11:07 AM
The link worked fine for me.
Tracy.
Alex 08-18-2005 11:14 AM
Page text
Originally Posted by RV_7A
linky no workee :)
Linky workees for me, but in case you can't see it, here's the text from the page at least:
High-powered, lightweight strobe/lighting systems now available in three configurations:
Skybright standard Skybright streamlined Skybright nightlights
Skybright nightlights . . .
A strobe/position-light system in our streamlined housing. A pair of units includes red (left) and green (right) forward LED lights and white rear LED lights, with our super-bright strobe in the center.
complete dual-strobe/light system... $329.00 strobe/position-lights - click for larger photo strobe/position-lights - click for larger photo
Skybright streamlined . . .
Our super-bright strobe in a lightweight, streamlined housing.
single strobe system... $160.00
dual strobe system... $220.00 streamlined strobe head - click for larger photo streamlined strobe head - click for larger photo
Skybright standard . . .
Our super-bright strobe in round housings. Strobe heads are 3.5" tall with a 2.2" diameter.
single strobe system... $149.00
dual strobe system... $199.00 standard strobe heads - click for larger photo strobe heads with power supply - click for larger photo
The Skybright strobe and strobe/position-light systems include the strobe power supply (requires 12VDC power). Our special strobe power supply is "programmable" to 12 different flash patterns! The system can be easily set for each strobe head to single-flash, double-flash, triple-flash, quad-flash, and in several alternating combinations. This special feature allows you to set the strobe flash pattern that will be most effective for your application and installation. The strobe power supply weights 17 oz. and draws 40 watts as 12v. The standard strobe heads weigh 4.5 oz. each while the streamlined strobe heads and strobe/position-light heads weigh 3.0 oz. each. Our strobe systems do not include strobe extension cables but we offer convenient pre-wired cables which we stock in lengths from 3' to 30' (also with bulk cable available) as listed below. Warranty: Two years on the strobe power supplies, two years on the LED lights, and one year on strobe bulbs.
strobe/position-lights - click for larger photo strobe/position-lights - click for larger photo streamlined heads with power supply - click for larger photo standard strobe head - click for larger photo
Strobe Extension Cables (light-duty, 3-conductor, 18 gauge, shielded) with prewired connectors . . .
3' extension cable with prewired connectors... $ 6.80
6' extension cable with prewired connectors... $ 7.70
8' extension cable with prewired connectors... $ 8.30
10' extension cable with prewired connectors... $ 8.90
15' extension cable with prewired connectors... $ 10.80
Please Note: for extension cables longer than 15', the heavy-duty (16 ga.) cable should be used instead of the light-duty cable. We offer the heavy-duty cable in bulk as listed below along with connectors.
heavy-duty cable (3-conductor, 16 gauge, shielded)... $ 0.60/foot (cable only)
male or female connectors including pins... $ 0.75/each
for more information or to place an order, please email or call . . .
Rollison Airplane Company, Inc.
Route #2, Box 186, Bloomfield, Indiana 47424
phone: 812-384-4972 fax: 812-384-0518 email: info@airplanegear.com
please also visit . . . www.RLSA.us
N941WR 08-19-2005 08:28 PM
Good for the wings...
but what about the white tail light and strobe? What are you going to do there? (Assuming the newer style wing tips.)
Do you have to use the Whelen's light/strobe combo?
ww2planes 08-19-2005 09:34 PM
Clarification
The strobe is included. you can simply run power to the tail light and that issue is taken care of. These light some in several combinations. Chack out the website. The one that is not pictured is the one that I will be using for my wingtips with the cutouts. These are position and strobe units similar to the piggyback style from Whelen.
N941WR 08-20-2005 02:53 PM
WW2P,
I'm confused by your reply. Are you saying the strobe power supply can power the tail strobe light?
penguin 08-20-2005 04:22 PM
Aeroflash?
It seems that Aeroflash strobes are not that much more, and you can put the power supply in the wing tip. But at least there is a choice.
Pete
