121.5 ELT phase out
In October 2000 the International Cospas-Sarsat Program, announced at its 25th Council Session held in London, UK that it plans to terminate satellite processing of distress signals from 121.5 and 243 MHz emergency beacons on February 1, 2009. All mariners, aviators, and individuals using emergency beacons on those frequencies will need to switch to those operating on the newer, more reliable, digital 406 MHz frequency if they want to be detected by satellites.
Read about it: http://www.sarsat.noaa.gov/phaseout.html I have no plans to upgrade to the 406 MHz ELT anytime soon. The price will come down but we will all be required to switch when the FAA gets around to requiring it. Gary A. Sobek RV-6, N157GS, RV-6, 1,749+ hours flying, SoCAL |
Things can change
I know artex has a unit for less than $1000. So it is not as bad as you might think. Still when you could get an ELT for $200-$300 it does hurt a little, but at least you are getting something for the extra money, accuracy, which may save you life, plus 5 year battery.
http://www.artex.net/documents/ME406.pdf One draw back besides the cost is you now need two antennas one for 400Hz and another for the lower freq. As far as 121.5 and 243 MHz, these freq will be monitored for a long time to come. Also 121.5 and/or 243 MHz will be used for local direction finding, so you need both. On the plus side the 400Mhz is way more accurate, and could save your life. The personal hand held 400MHz units are nice and cost in the $600 range. These are little units are small and can be carried in your hand. They don't meet the aviation requirment but they are nice and can be used for other purpose than aviation. These personal units are better than the least Artex has units above in one way, with built in GPS. You don?t get GPS with aviation 400MHz ELTs until you get into the big bucks. The new 400MHz has the ability to transmit the exact lat-long interfaced with a GPS input. If you want an ELT 400MHz with nav capability they cost about $1700. The nav interface is another $1500. So for over $3000 you can have the full meal deal. The 400MHz date could be moved back down the road , so 121.5 & 243 MHz may be around for a while longer than 2009. The 243MHz may drop out but 121.5 MHz will always be used. I am all for the new technology and a baisc unit without GPS provides very good position. Cheers George |
I was reading one of the aviation mags recently (Pilot Getaways?). In their article about this phase out, they talked with ACK. ACK says they will have a 406MHz ELT out next year. Only a few hundred dollars ($500-$600 - can't remember) and it will 'drop in' to their existing cradles. You will need to add a 406MHz antenna.
Supposedly they even include pins to accept data from your GPS. If the ELT activates, they will include the last position it received from the GPS. Kevin |
ELT phase out
Of course every pilot will have to weigh the issue for themselves of whether they want to upgrade to the better technology to allow for easier location by emergency responders in the event of a mishap that will require the use of the ELT. But it appears that the FAA is not planning to force us to transition to the newer technolgy if we already possess an ELT. Steve RVBYSDI |
elt's -- 406, 121.5, and epirb's
my current strategy (subject to change without notice when somebody points out what a bad idea is it) is to use a 121.5 mhz elt to satisfy the regulatory requirement and obtain one of the relatively inexpensive (~$595) epirb's for that "added benefit". of course, if the 406 mhz elt's get down into that range, then i'll just get one of those.
john |
As long as the 121.5 equipment is still legal, I would see no reason to change. |
ELT Single Antenna
FYI,
Artex does make a single antenna that transmits all three frequencies and an ELT that will feed it on just one coax. I'm installing it on a Hawker 800 now. Way to $$$ and heavy for us though :( I talked to our DAS admin and local FSDO recently about this and I can find no plans to force experimentals to the 3 freq requirement. Will, Avionics Engineer, Gulfstream |
| All times are GMT -6. The time now is 06:48 PM. |
