VAF Forums
-   Nosewheel vs. Tailwheel (https://vansairforce.net/community/forumdisplay.php?f=56)
-   -   Taildragger Training (https://vansairforce.net/community/showthread.php?t=27544)
Geico266 03-04-2008 05:08 PM
Well, I decided the time was right to get my TD endorsement so it was off to see my local CFI and his 1941Interstate. After 2.3 hours of flight instruction I can honestly say I have a ton more respect for the tail dragger pilots and their machines. I had a ton of fun learning how to plant the tire in a 15 MPH cross wind, taxing on the ground with said wind, and a few "assisted" wheel landings. I kept her pretty straight, but was sure glad the instructor was there.
Any tips for the new / old student TD pilot? I'm reading Tail dragger Techniques.
dprill 03-04-2008 05:25 PM
Practice, practice, practice, and then more practice.
RV8iator 03-04-2008 05:39 PM
Never, Ever,
quit flying it until it's in the chocks..
what fun, eh
MacNab 03-04-2008 05:48 PM
Do as many takeoffs and landings in as many varied conditions and configurations as you possibly can over the shortest time interval that you can...then don't stop. :)
Like the man said, practice, practice, practice. But especially spend a lot of time in the pattern at different locations and also concentrate on precision ground work - like you are on a police motorcycle drill team. Pay attention to the state of your body and mind, and stay relaxed, but always stay on your guard. Don't let a little excursion turn into a big one by learning to recognize it and stop it NOW with the appropriate control input.
I'll bet your instructor already told you all that stuff, didn't he?
John Clark 03-04-2008 05:55 PM
Use those feet!
I'll second the practice comment but there are a few things you need to think about. First and foremost, think about the dynamics of a taildragger. The center of gravity is behind the main gear. Landing a taildragger is a little like trying to shoot an arrow tail first. The airplane wants to put the CG in front of the gear. Your main job is to keep that from happening. The easy way to do it is keep it as straight as possible. Takeoff is a little easier because you are accelerating, but while landing the tail really wants to lead the parade. Remember too that there will be 'P' factor issues on takeoff as the tail comes up. The angle of attack lessens as the tail rises, requiring less right rudder. So in practice, you blast down the runway as long as the tailwheel is on the ground the rudder will be fairly neutral. Then you raise the tail and the sucker wants to go left but as the tail rises the left tendency lessens. Here's a tip, don't sweat all the above, focus down the runway a ways and keep the airplane straight!!
Bottom line, don't sweat it. It will make sense soon and then it will be instinctive.
John Clark
RV8 N18U "Sunshine"
KSBA
Geico266 03-04-2008 06:00 PM
Well, yes, .....but to teach an "old dog" new tricks takes repeating things several times, or a 2x4. :rolleyes:
I can see why the better tail dragger pilots at my airport spend hours in the pattern. Pratice, Practice, Practice, then Practive some more.
It is totally fun though. This old "41" Interstate is a really cool old machine. No starter, no electrical, no mixture. Just carb heat below 1,500RPM, throttle, mags, cabin heat. 75 HP, 75 MPH max cruise, 37 MPH stall, no flaps. Most fun flying I've had in months. Low & Slow is the way to Go.
My head will be spinning for days. :D I know I could have done better!
Geico266 03-04-2008 06:06 PM
Great advice! I did pick up on it becoming easier looking down the runway. I'm gonna stick with it, as long as the instructor puts up with me!:) This has been an aviation goal of mine since I started flying. Tail Dragger Pilot.
It does force you to be a better pilot.
mannanj 03-04-2008 06:19 PM
TD's
Dont say that-----You'll start another ND vs. TD war!:p
Geico266 03-06-2008 01:12 PM
Lesson #2
It was a no wind day so I got to get some good wheel landings in. What a difference it makes when you don't have to correct for a cross wind. I did pretty good on the rudder, but I need to learn to neutralize them each time I "stab" for a correction. Got a tad squirreling a couple of times, but always was able to keep her under control. There was a couple of times the ossolations started (pilot induced) and I was bale to get ahead of them quickly without making them worse. CFI says I should be done soon, but he will not sign me off until we get some more cross wind landings in. Fair enough.
What are some suggestions for three point lands? I know look down the runway and not in front of the plane seems to work really good for me.
Keep those tips coming!
pierre smith 03-06-2008 01:51 PM
Look at the horizon..
Hi Larry,
The next time you taxi out onto the runway, look at the relationship between the cowl and the trees or whatever is on the far end. I mean the height of trees or buildings in relation to the cowl. My buddy's -4 will have the trees about two inches below the top of the cowl...this way, during the flare to land, you know when you've put the airplane in the same attitude it was in on the ground and all three wheels should touch down together.
Yep...practise, practise,
