Prop Bolt Holes in Spinner Bulkhead
My prop bolts are 1/2 inch and the holes in the rear spinner bulkhead are 5/8, so it looks like the only thing keeping the spinner bulkhead from turning are the two locating dowels on my metal Sensenich prop. Have I got this right?
Same here
Mine is the same, I assume this is correct, there will also be quite a bit of compression on the bulkhead from the prop bolts.
Agree with above poster. My backing plate is a precesion fit also. FWIW I have my comm antenna under my feet between the gear legs and my xponder antenna on the bottom just aft of the rear baggage bulkhead. Have not had any complaints on xmitt or reception.
Tom RV3 2000+ hours |
| All times are GMT -6. The time now is 06:38 PM. |
