How do you start your EI engine?
It has taken me a while to figure out the best way to start my carburetored electronic ignition engine.
How are the rest of you starting your engines? When cold, I start mine using the following technique: Turn on the master Turn on the boost pump Mixture full rich Pump the throttle once Pull the mixture to idle cut off Turn off the boost pump Turn off the master Turn the prop by hand through eight compression strokes Get in and buckle up. (When the engine is warm, I use the following technique.) P-mags on Mixture full rich Throttle closed Boost pump on Press the starter Advance throttle until the engine catches. PS. No primer is installed |
O320, carb, mag, EI, wood prop
Mixture rich Throttle in 1/4 inch Master on Mag on EI on Boost on Primer on for 3 sec (2 times in cold weather, but not needed if engine is warm) Mash the starter Works every time! Of course, cold weather in Georgia is about 40 deg! I never need to pump the throttle while cranking. I have read about, but never tried, priming the cylinders then waiting a few minutes for the fuel to vaporize before attempting to start. It is supposed to make cold starts easier. |
See other thread on pumping the throttle to decide on this.
Here is what I do.
1.) Mixture Rich 2.) Throttle to 1/2 inch (equal to 1000rpm setting when you shut down). DO NOT PUMP the throttle in my opinion, it can cause fires and has done so many times. 3.) Boost pump on for 2 seconds, then off. 4.) Pump the primer 4 times (assuming you have a primer line on three cylinders) 2.) Electronic Ignitions On 3.) Master and Alt on 4.)Engage the starter. If it does not fire with 3-5 rotations, then start checking the induction system for leaks. I have two lightspeed Plasma II's and mine starts first time every time without ever pumping the throttle. H. |
Simple start
Master on
emags on throttle & mixture full in fuel pump for 10 seconds throttle out Pump throttle once (twice if it near freezing) push the starter lean once its running Rarely does the prop make 2 fulls rev before starting If the motor is warm I skip the prime with the throttle |
I would change one thing for sure
Turning the prop by hand? That is not needed in my opinion. Do you have a combo mag/ign/starter key switch or separate starter button. Can you turn the engine with the starter and IGN off? The hand prop deal was with radials that would collect oil in the bottom jugs and could hydraulic the rod, aka bend it. Also mixture rich is not needed to prime with the throttle I believe. You can pump the throttle either way. Do you leave the mixture rich and hand turning the prop? :eek: What if one of the ignitions are hot? Just saying. Of course always treat the prop as live and I would not turn the prop with the mixture rich! :eek: There is nothing wrong with your technique, but it seems busy. Less is more. I guess I would skip the getting out and hand turning the prop over. If you feel you MUST do it, than just do it during preflight, before you get in or pump the throttle (of course checking Ign and mixture are safe first). You are not drawing in the fuel you pumped into the throttle and airbox when you hand turn the prop. IF ITS COLD, I WOULD WAIT A LITTLE TIME BEFORE (PUMP) PRIME AND CRANK. It give the fuel a little time to vapor off. While you wait you can get you belts on, and also you can give it pump if needed while cranking. Search for that carb prime pump thread, it's worth a read. |
George,
I have checked all the treads and tried a number of different things until I settled on the above. I would agree with your warning, if I was using traditional magnetos, but I'm not so the risk is minimal. Thus this tread in the EI list. Regarding propping with the starter, when it is cold, I prefer to turn the engine over by hand. Just a throw back to turning radials over by hand. There is almost no chance of my P-mags firing in the scenario I described. To feed power to my duel P-mags the Master and the P-mag switches have to be on. Thus double protection, the mag switches and the master. The P-mags will not fire w/o electricity applied and my switch setup removes power and grounds them, another double protection. Then add to that internal P-mag function which keeps them from firing until they see three revelations at a set speed. All in all, this is about as safe as it can get. Still, I treat the prop like a loaded gun. Every year, a number of people get shot by "unloaded guns" and I don?t want to be one of them. Oh, and yes, I do pull the mixture back when hand propping. As always, thanks for the thoughtful and extensive input, I'm still learning how to live with this engine, carb, ignition combination. |
Install a primer?????
Almost? ha ha
As I said, the P-mags don't fire until after three revolutions and then it fires on both the compression and exhaust strokes at the same time, causing some kick back when there is excessive amounts of fuel in intake. Less pumping of the throttle seems to have solved that for me. I have no desire to install a primer, now that I have figured out how to start this engine with its unique combination of carburetor and electronic ignition. |
| All times are GMT -6. The time now is 04:15 AM. |
