Tip: Go-fast baffling: RTV & glass
I?ve had a couple people email me asking how I constructed my RTV & fiberglass baffing for my VariEze. I found that this was a great way to keep my hopped up O-200 cool & the drag low. The goal of this was put all the air where you want it & not let any leak to where you don?t want it. It?s a very messy process, but gives an amazing seal around the cooling fins. Here's a writeup I did on the process dug up from my personal VariEze archives (from 1998):
This is how I did my RTV/glass cylinder baffling for my O-200 powered VariEze. This worked for me & really helps cool even my hopped up motor efficiently...no guarantees on your installation though. :cool: Some aluminum is still required, but not really around the cylinders. I have some between the skinny parts of the cylinders that I re-used from my old baffling installation, but you could actually lay up a solid glass piece to put there or maybe a smaller aluminum piece than I have. If you got a little creative, you could even put RTV/glass there. The front, side & back baffling pieces still have to be made of something rigid. Aluminum or epoxy/glass or carbon should work fine. I bought Hi-Temp red (looks orange) RTV from Autozone, PepBoys or some such auto parts store. They sell it in big tubes that you can put in a caulking gun. I used several of these tubes to finish the project. I think they cost about $10 a piece (maybe less - can't remember exactly). The red RTV is the highest temp stuff they sell, but you could maybe get away with a cooler temp RTV if you wanted a better color. Not sure on that one, but the temps at the outside of your cooling fins shouldn't be all that hot. I used 1 layer of 5oz BID fiberglass in my RTV layups. I'm not exactly sure how much extra cooling this style will get you. I did mine during an engine rebuild where I pumped up my motor considerably, so it's tough to tell the benefit exactly. Before the rebuild, my engine ran at about 425F CHT in climbout & about 400 in cruise. After adding at least 30hp to the engine (should make for hotter CHT's) and the RTV/glass baffling, I now run about 380 on climbout & about 350 in cruise. By my math, the RTV/glass baffling helps.WARNING - NON-RV PICTURES BELOW!! ![]() ![]() ![]() ![]() ![]() While I did this project on a plastic plane, I think it could yield the drag-concious builder a little less drag in his/her RV. Hmmm...maybe it's time for me to start another project on my plane. :D Moderators: You may have to move this thread..."general" seemed to be the best fit I could find, but "Tips" might also be a good place. |
| All times are GMT -6. The time now is 07:33 PM. |
