VAF Forums
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   P-mag (or E-mag) and AFS manifold connectors (https://vansairforce.net/community/showthread.php?t=26676)
Steve Sampson 02-09-2008 03:59 PM
I have to connect manifold pressure to an AFS 3400 and P-mags. Has anyone got some good pictures (or a list) detailing the various connectors/parts they used. I cant find anything in the archives though I thought I saw something recently.
Thanks.
Davepar 02-09-2008 10:01 PM
I put the AFS sensor on the front of the firewall and used high-temp silicone tubing (same stuff that comes with the P-mags, just larger) and polycarbonate Ts for all the connections. Very easy to install. See this post in my log:
http://www.dualrudder.com/rv7/2006/11/06/1095
This post shows the fitting I used in the cylinder. I epoxied in a rivet with a small hole in it to act as a restrictor in case the hose ever breaks.
http://www.dualrudder.com/rv7/2006/11/17/1106
I used these clips over the hose on the non-barbed fittings just to make sure they weren't coming off:
http://www.aircraftspruce.com/catalo...erbieclips.php
Dave
N941WR 03-05-2008 05:09 PM
Try a Universal Hose Adapter
Try a Universal Hose Adapter.
The -4D worked good for me and it allowed me to install the sensor aft of the firewall, out of the weather and heat of the engine bay.
