How do I remove a prop extension from the prop
I have a Sensenich aluminum prop with a 4" extension. They have been working together for 200 hours. I now need to separate them.
How does one go about getting them apart? I suppose a hammer, but what do I hammer on? Thanks, Duane |
Pound th pins out
My manual says-- use a steel rod no bigger than your pins, use a 5lb hammer with alternating blows, do not **** the spacer, they are very tightby design.
**** naughty word means-(uneven) I suppose it could be naughty? |
Instructions
http://www.sensenich.com/new/70cminst.htm gil A |
| All times are GMT -6. The time now is 06:43 PM. |
