VAF Forums
-   Alternative Engines (https://vansairforce.net/community/forumdisplay.php?f=22)
-   -   New Alternate Engine ??? (https://vansairforce.net/community/showthread.php?t=25601)
RV6_flyer 01-12-2008 05:54 AM
Van is smarter than I am so I follow his recommendation on engines for RVs.
I know there are many people that do not like to follow recommendations of successful designers.
Here is something I found in a car forum that I read. Talk about a NEW design that has potential. Wow!
The MYT™ (Massive Yet Tiny) Engine
http://www.angellabsllc.com/index.html
Video:
http://www.youtube.com/watch?v=_MBYg1NPzMY
I know it is too light weight and too much HP for an RV.
Geico266 01-12-2008 06:15 AM
Great idea, great design. It would be even better if they had a running model.
MacNab 01-12-2008 08:36 AM
I see in this video http://www.youtube.com/watch?v=kGlUZg2pC0Q&NR=1 that Raphial is talking about scaling the engine for lower horsepower (200 hp was mentioned). C of G issues would still need to be resolved for application to existing light aircraft designs. A whole new aircraft designed around this engine would be very interesting to see. I'm guessing you would also see some pretty unusual propeller designs to take advantage of the torque output, as well. I'm curious as to what kind of power pulse and vibration characteristics this engine might have at direct drive operating RPM's.
RichB 01-12-2008 09:11 AM
Seconded. Looks like a cool concept, but I'm sceptical about the numbers. I'm calling shenanigans until I see one running.
airguy 01-12-2008 09:26 AM
I like the concept, it may be very workable, but I've got more questions than answers. I don't see any real detail on the site at all - it appears the two rotating vane sets are in a TV-like mode with respect to each other, driven by pressure pulses. I'd like to know how they are entrained to maintain that motion, how do they couple power to the crankshaft, how do they seal to the face (outside edge) of the chamber as they rotate.
Also, from the animation it's apparent that the combustion always takes place at the same two places on the outside radius of the case - those will be intense hot spots and cooling will be a very interesting animal to tame. With a round case and localized heating at opposed points, you'll oval out that case in a heartbeat, defeating a perfectly circular rotor(s), so a novel sealing system (or a kick-butt cooling system) is needed. The rotors will not be coolable by water jacket, so some heavy oil cooling from a ported crankshaft will be needed.
I like the concept - I want to see one run in a test cell.
Yukon 01-13-2008 08:50 AM
How can they make all these claims without a functioning prototype?
SvingenB 01-13-2008 12:10 PM
I agree. But isn't this just a re-vitalized steam engine concept from way back?
zzapp 01-13-2008 12:19 PM
Ya gotta prove it.
" How can they make all these claims without a functioning prototype?
Yesterday 11:26 AM"
You can claim anything you want but as the direction of this thread is taking your credibility is suspect until proved otherwise. Leonardo DaVinci's flying machine probably looked pretty impressive when first drawn up but we all know how well it couldn't fly. Our mechanisms have become so sophisticated a quantum improvement is difficult. I'm cheering for it anyway. Love to see innovation.
John Clark 01-13-2008 01:19 PM
Stay tuned
Speaking of credibility, here is a quote the inventor, Mr. Morgado:
"By replacing an 800 pound V-8 engine with a 25 pound MYT and running it on biodiesel, we can achieve 150 miles per gallon in an otherwise conventional vehicle -- plus, you're going to have better take-off and stopping power by removing that 800 pound engine. That's what we can do. It is achievable." - Raphial Morgado
I'm going to need a little convincing that an 800 cubic inch diesel will get 150 MPG in an SUV. He would have had my attention if he had just said something about the mileage improvement due to lower weigh of the powerplant. It is new "monkey motion" connected to what is a two-stroke diesel. It won't change the laws of thermodynamics. I am, however really interested is seeing how he seals the "slot" in the cylinder wall that connects the pistons to the system.
John Clark
RV8 N18U "Sunshine"
KSBA
w1curtis 01-13-2008 01:43 PM
The concept is great and not being reciprocating should/would provide turbine link smoothness and high torque at low RPMs with piston efficiencies. The mechanics of "locking" the magenta "pistons" in place so that the combustion can react against the blue "pistons" would be the challenge.
