Panel Switch Spacing
Hello,
What is the standard spacing for panel toggle switches? Thanks, Pete Howell |
Switch spacing
It depends on the switches (regular, mini, micro). If you are using 'regular' single pole switches like those sold by Stein and B&C, the switches are .75 wide so you could space them as close as 7/8" centers, but right now I'm planning to use 1" center spacing. If you have any multi-pole switches, they may be wider...
Dennis Glaeser RV7A Empennage |
| All times are GMT -6. The time now is 06:49 PM. |
