Garmin 496 audio out question
I used a standard stereo cable from the 496 to my panel's music-in jack but I don't hear anything. I initially thought it was the music-in jack on the panel that was the problem, but I just tried plugging my iPod Nano into the panel using the same cable and it worked perfectly.
Is there some setting or something else I need to make the 496 audio output work? I have the XM weather and audio subscription and it has worked fine using the in-line speaker on the 12v DC power connector. I know I could probably find this in the manual, but I am hoping someone else has already solved the problem. thanks, |
There are music out settings, or mute settings you may have to check out. Look in the audio section, or settings. Check the volume also.
| All times are GMT -6. The time now is 09:22 PM. |
