VAF Forums
-   RV Ongoing Maintenance Issues (https://vansairforce.net/community/forumdisplay.php?f=76)
-   -   90 deg oil hsg clearance with tach transducer (https://vansairforce.net/community/showthread.php?t=24296)
dalekline 12-05-2007 08:35 AM
I would like to install Van's tach transducer on 0-320, but not sure if there's enough clearance with the Casper labs 90 deg. oil housing. Wondering if anyone else has had a successful installation with this combination?
Dale, RV6A
Steve 12-05-2007 12:08 PM
extension cable
I had to buy Vans 12" extension cable to move my Vans tach generator away from my ECI 90 degree oil filter adapter. Make a simple aluminum mount and attach the the assy to a motor mount tube with an Adele clamp. Fastenal stocks thin jam nuts to hold the gen to the mount.
Steve
