VAF Forums
-   RV Ongoing Maintenance Issues (https://vansairforce.net/community/forumdisplay.php?f=76)
-   -   TIME TO CHANGE THE MOTOR MOUNTS.... (https://vansairforce.net/community/showthread.php?t=24243)
gasman 12-03-2007 06:31 PM
Can the LORD mounts be changed one at a time? If so, what order would be best to use?....................:).............thanks
gasman 12-04-2007 10:04 AM
Still looking
gasman 12-04-2007 07:26 PM
Well then, I guess I will take on the learning curve. When the task is complete and I have my new LORD mounts installed, would anyone like to know how I did it?
frankh 12-04-2007 10:48 PM
Sure
Butt I think your going to use an engine crane and just support the weight of the motor, remove bolts, mounts and replace.
don't see why you need to remove any cables or wires or anything.
Good luck
Frank
atreff 12-05-2007 10:10 AM
No removal necessary
When I was swapping Lyc's and Conti's for an air freight outfit, we did em one at a time all the time. You do need an engine hoist, and I usually start with the lower ones.
Art in Asheville
