Warnke bolt torque?
Anyone have the torque values for a Warnke wood prop? Installed on an O-320 .Tis the season to check them.
Thanks, Dennis |
The recommended torque on my Aymar Demuth is 18 ft*lbs. The prop is made of Rock Maple. Hopefully this helps you.
You could always check the RV-list archives. There is a wealth of information there and it probably includes a torque setting for a Warnke prop. |
Wood Prop Bolt Torque
Hi Dennis, I have a Warnke ground adjustable on another airplane and needed the same information. Try the Sensenich wood prop web site at:
http://www.sensenichprop.com/sen_htm...stall/cf-a.pdf Good information there and they have a chart based on prop bolt diameter. Mitch Garner RV-4 flying PL-4 flying |
Good info. Thanks fellas.
DM |
Dennis,
My '92 RV-6 had a Warnke prop. I spoke to Bernie a number of times regarding the prop. I double checked my notes where he told me that 22-25 ft/lbs was the appropriate torque. |
| All times are GMT -6. The time now is 06:43 PM. |
