VAF Forums
-   Propellers (https://vansairforce.net/community/forumdisplay.php?f=19)
-   -   Prop Bolt Torque (https://vansairforce.net/community/showthread.php?t=24185)
n38139 12-02-2007 07:23 AM
Prop Bolt Torque
Where can I find the correct prop bolt torque for a new Hartzell?
thanks,
Steve
Kevin Horton 12-02-2007 07:50 AM
You find it in the Hartzell manual that comes in the box with the prop.
What model Hartzell do you have? I can look in my Hartzell manual.
n38139 12-02-2007 09:36 AM
C2YR-1BF/F74972
C2YR-1BF/F74972
thanks
Kevin Horton 12-02-2007 10:08 AM
The table on page 307 of my Hartzell Propeller Owner's Manual, dated September 2000, lists the torque for the prop mounting studs as 60-70 ft-lbs. This value is applicable to K and R flange props (yours is an R flange - C2YR-1BF). The torque value for other types of flanges is different.
