VAF Forums
-   GPS (https://vansairforce.net/community/forumdisplay.php?f=39)
-   -   GPS and XM Antenna Mounting Position? (https://vansairforce.net/community/showthread.php?t=24132)
jsharkey 11-30-2007 02:34 PM
I was considering mounting the GPS and XM antennas on top of my RV6 Tip-Up glare shield just like the compass.
Anyone else done that? Wiring will be simpe.
I'm assuming that they can "see" through the plexi.
Any other ideas or comments?
Jim Sharkey
Transporter 11-30-2007 03:00 PM
Other options
Bill Gill (N151WP - see first flight info on the main page) mounted the GPS antenna on a firewall bracket under his RV7 cowl. Don't know if others have tried this, but his GPS seems to get a nice strong signal through the fiberglass...
Regards,
Mike
Bevan 11-30-2007 03:41 PM
GPA antenna location
I don't care for the idea of putting an antenna near the engine due to heat. Dan C has his GPS antenna FWF and had to replace it for an unknown cause. Wouldn't it be better on the glairshield under the windshield? An added benefit here is short and light antenna wire. Is there a down side to this location?
Bevan
RV7A wiring
Ironflight 11-30-2007 04:57 PM
My prime antenna is under the cowl, but I have a backup GPS, 396 GPS, and XM antenna on my -8's glareshield. The downside? You see them reflected in the middle of your windshield much of the time.....
Paul
jsharkey 11-30-2007 05:10 PM
Paul
Good info Paul - how good is the signal from the glare shield mount?
Jim Sharkey
Delta Bravo 11-30-2007 05:41 PM
gps Antenna location
Hi,
On my 7A my under cowl antenna location worked fine the first year but this past Arizona summer I has several temporary losses of signal to my Garmin 430 following an intermediate stop and the subsequent heat soaking after parking for 30 minutes or so. After departure and reaching cruise the antenna would resume operation. I'm going to switch to location on the top of the aft fuselage.
Don Bodnar
bsacks05 11-30-2007 05:43 PM
My XM and GPS antennea on mounted on the glare shield on either side of the roll support bar on my -9 slider. They are as far fwd as possible without touching the windscreen. Never a problem and almost out of sight.
jsharkey 11-30-2007 06:04 PM
Do they have a good signal?
petehowell 11-30-2007 06:07 PM
Good Signal
My XM and GPS antennas are on the glareshield of my -9A slider. Always work well.
jsharkey 11-30-2007 06:12 PM
Thanks!
Jim Sharkey
