VAF Forums
-   RV Ongoing Maintenance Issues (https://vansairforce.net/community/forumdisplay.php?f=76)
-   -   Part numbers for brake caliper o-rings (https://vansairforce.net/community/showthread.php?t=24050)
penguin 11-28-2007 03:06 PM
Hi,
I have to rebuild the brake calipers on my airplane so I'm looking for a little help to find the part number for the caliper O-ring kit. This is a regular Cleveland brake caliper, does anyone have the number? Do the usual culprits keep them in stock?
Thanks, Pete
flyeyes 11-28-2007 04:49 PM
Originally Posted by penguin (Post 175091)
Hi,
Thanks, Pete
Here is a cut and paste from the e-mail last time I ordered some o-rings:
O-RINGS, INC.
Order Number: 938
Date Ordered: Thursday 27 July, 2006
Products
12 x -218 V90 (1.234 X 0.139) () = $8.40
Packaging Bulk Pkg
Lubrication None (No Charge)
1 x KIT BN70 () = $18.00
Packaging Bulk Pkg
12 x -218 V75 (1.234 X 0.139) () = $6.00
Packaging Bulk Pkg
Sub-Total: $32.40
Table Rate (US Ground Shipping): $6.00
Total: $38.40
I ordered these (and extras for spares/buddies) from O-rings USA. Note that these are the Viton o-rings, which are compatible with both the "regular" hydraulic fluid and the higher-temp 83282 which I use. The Viton rings are better able to resist high temps and are a drop-in replacement.
The ring size you want is the -218, I think you can use either durometer of the Viton (V75 or V90). I'm currently using the V75s on my RV-8 and they work well.
The BN70 "Kit" was the plastic box full of every size o-ring that a lot of FBOs have. It's useful to have around.
Hope this helps.
penguin 11-30-2007 08:37 PM
James,
Thanks very much, that's exactly what I needed.
Peter
wv4i 12-02-2007 06:13 PM
Cleveland Brakes Exploded View
Also can find exploded view in 2006-2007 Spruce Catalog, p.230, or online. Spruce o-ring part no is 101-02300. Pls note that it is possible to install the piston backwards, not good.
drmax 09-12-2012 01:41 PM
that part number is not the higher grade o-ring. this is the older style. i've called and talked with spruce about this.
