VAF Forums
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   Hall Effect Light Speed (https://vansairforce.net/community/showthread.php?t=23683)
LifeofReiley 11-18-2007 06:47 PM
Okay... I've ordered my LS Ignition, has anyone really has any issues with this system? I know about the inspection time frames but has anyone ever really had a maintenance issue with this system?
RVadmirer 11-18-2007 07:40 PM
Installation
Keep the wires providing sensor info from the Hall Effect separate from the output to the coils by as much as is practical in your case. Mine were installed in the same firewall hole and the unit failed within 30 hours. Now, properly mounted, 100 hours trouble free.
LifeofReiley 11-18-2007 07:52 PM
Good Info... any reason to have a cooler shroud on it?
gmcjetpilot 11-18-2007 08:16 PM
Mag housing inspection maintenance
Per the other current thread the hall effect mag housing trigger needs a one time gear inspection in the first 50 hours and than every 100 hours the cover needs to be checked for leaks.
LifeofReiley 11-18-2007 08:34 PM
I understand the inspection issue, I'm looking for real data on actual issues with this system. Has anyone ever really found an issue on inspection? It looks like Van's only offers this Hall Effect style unit. I haven't seen a Mandatory Service Bulletin on the system yet.
LifeofReiley 11-19-2007 11:11 AM
Killed that order!
Killed that Hall Effect order today... Direct Crank sensor it is, Plasma II.
