Oil Burn in a 0-360 ?
I am looking at a 6 with a 180+ HP 0-360 A1D with Fuel Injection engine. it has about 300+hours on it in 10 years. good compression however the current owner say it burns 1 qt per 4 hours of flight.
does this seem normal? Thanks In Advance Jim |
Well he is honest
Lycoming does not publish an exact oil use except for break-in but guide lines. 4 hr/qt could be considered normal with caveats. Personally I like to see at least 8 hr/qt or better. Frankly my O360 was in the 16 hr/qt per hour range after 900 hours, but than I flew it 300 hours in 2 years not 10 years. The low hours bothers me the most. Lycoming says an engine that gets 4 hrs/qt or 20 hrs/qt can both be healthy. There's other criteria to judge health. Compression, power and limits. Is oil temp & pressure OK? Is the oil filter free of debris? Last but not least is trend monitoring of oil use. If its always used oil 4 hr/qt it may be normal. It's also possible the rings never seated. Also any time oil use JUMPS more than a qt you may want start to investigate. I would consider getting an AI to do the compression check for you independently and even bore-scope the cylinders and possibly look at the cam (some small dis assembly needed). If it cost a few $100 its worth it. Oil use is a function how harder you run it and how much you fly. Engines run frequently are better and use less oil than ones infrequently flown. You can have bad rings, valve guides that allow more oil use. Seal leaks can be an issue as well. A Lyc will run fine using oil if the plugs are not fouled and all limits are in the green. However I would not like 4 hr/qt personally. It would bug me. Here are some PDF's of Lycoming Key Reprints, where they discuss oil consumption and "what does it mean?" Look in General, Maintenance and Operations. Good info in there. What ever you pay plan on a top end or about $4,000-$5,000 in the price. Now compare to an ALL brand new 360 for about $21,000. Don't pay too much. A complete overhaul may be in the $10,000-$14,000 range or more. If you pay $10,000 and find you need an overhaul, it may cost you a lot more than just buying new. Plus you get a warranty with a new engine. http://www.lycoming.textron.com/supp...ints/index.jsp Here is just a few excerpts from Lycomings Key Reprints: QUESTION: At what rate of oil consumption does continued operation of the engine become a hazard? ANSWER: Generally speaking, when the oil consumption reaches one quart per hour, corrective action should be taken. However, maximum permissible for each particular engine is listed in the engine operator’s manual. QUESTION: What are the dangers of operating an engine with high oil consumption? ANSWER: When excessive amounts of oil get past the rings, there is danger of the ring sticking or breaking with a dramatic rise in oil consumption. Then oil soaked carbon forms at a fast rate. At the same time, the presence of oil in the combustion chamber has the effect of lowering the octane rating of the fuel. Operating temperatures go up. We have now set up conditions inviting detonation and/or preignition. QUESTION: What are some common causes of excessive oil consumption other than the burning of oil due to high engine time? ANSWER: Building up of crankcase pressure due to “blow-by” caused by ring wear may result in oil being blown out of the breather. The same thing can result from broken piston rings. Oil may be pumped overboard due to a faulty vacuum pump or faulty automotive-type fuel pump. |
If he is keeping it filled to 8qts it's not burning the oil. It's blowing out the breather.
If you do a compression check on each cyl and put a hose in your ear and the other end in (1) oil filler tube (2) Injection servo/carb (3) exhaust and they all sound similar and the compression readings are similar and the sparks plugs are not oil soaked....... then there is probably nothing wrong with the engine and if you ran it at 6 qts the burn rate(loss rate) would change. Ask him how long it takes for the oil to get dark..... if he says fast like less than 10 hours that's not good...... perhaps worn cyl or broken ring.... in which case the offending jug might show (1) oily spark plugs (2) hissing sound out the oil filler tube as described above. Not the end of the world easy repair. |
Who knows
If you have to start replacing jugs you should replace all of them. Often when you put one new one bad things happen in short order to the other ones. Just my opinion and experience. |
Good advice all...thanks
Oil blowing myth
The story I heard/read somewhere is that the FAA required engines to be able to run successfully on a small percentage of their oil capacity. Don't remember the percentage, but let's say it was 25%.
So if the engine makers determined that an engine needed 2 qts to run successfully, they filled the sumps up as full as they could get them, in this hypothetical case, 8 qts. This became the certificated "full" mark on the stick. If not for the certification requirements, the full mark would have been lower, say around 6.5 to 7 qts. In a wet sump engine, if the oil level is too high, the crank and rods splash the oil as they spin, and even cause the oil to foam, which allows it to get blown out of the breather. Once the oil gets below the level at which it gets foamed up by the crank, no more foam, and no more oil blowing out. This scenario is not true for dry-sump engines, such as the Pratt-Whitney R-1340 and many others, because the oil is in a remote tank, and can't get "foamed" by the crank. OTOH, this just might be another one of them pesky urban legends!:rolleyes: |
Good Luck, Mahlon "The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk." |
You're close
Pete, you're close. The FAA requirement is for the sump to hold twice the minimum oil. For my 180 Lyc it's 8 quarts and Lyc's min is 4 qts. I run 6 and don't add 'til it's below 5. Yes...it foams more than 6 out.
I keep mine at 6 qts
If I put 8 qts in my 0-360 I get a rapid reduction to 6 quarts in under 10 hours. It is all most likely coming out of the breather as the belly gets plenty messy. When it gets down to 6 quarts it stays there until my next oil change and the belly is much cleaner. I actually now only put in 7 quarts at oil change and then add the 8th quart at around 18 hours to keep it above the 6 quart line on the stick. I call that "no oil consumption" as I only use 8 quarts total for the oil change cycle.
| All times are GMT -6. The time now is 06:09 PM. |
