I've been researching the bigger tires since before I bought my RV-8. Very happy I found this thread.
If you want to go bigger yet I put a set of 21" on my RV4. No wheel pants then of course.
What size are you using on the rear ?
I am close to install the whell pants on my 7. I intent to land on gravel/grass strips later and understand that a larger tire (like the 380) should help in that regard. On the other side i hate to throw stuff away and the installed stock tires do look perfect. So my questions to the guys who switched to larger tires: Is it really a noticable improvement during TO/landing on grass/dirt strips?
Kay |
I?d say it?s a noticeable improvement for soft field stuff. The grass strip I was once on was really soft and it helped a lot. If the grass you intend to visit isn?t really soft I wouldn?t bother with the 380?s. After I switched to the 380?s I developed a slight shimmy at around 30kts.
This is a good thread:
http://www.vansairforce.com/communit...v-6+bush+plane |
It was a noticeable improvement for me in rough/soft field ops. But it made the gear legs on my RV-7 shake like a paint mixer on landing starting around 30 knots, until I slowed to below 20. I tried balancing (repeatedly) and even another set of tires. The wood gear leg stiffeners offered for sale occasionally on this forum killed off about 99% of that. As is often pointed out, every RV is different. YMMV.
They shake because they can be up to 1/2" out of round NEW. All aircraft tires are this way, even jet tires. My neighbor who flies/maintains a Falcon 900 changed the nosegear tires on his jet and it shimmied bad even after perfectly balancing them. He chucked them on his lathe, saw they were out-of-round and Goodyear sent him a new set of tires. He checked the replacements and they were minimally out of round. No shimmy.
The out-of-roundness is from where the plies overlap. That also forces the tire to have a localized stiff spot as the overlap patch is run over which also causes shimmy/oscillation. |
| All times are GMT -6. The time now is 07:05 PM. |
