EFI Fuel Return Line Plumbing
I am about 99.9% sure that I have decided to put a rotary engine in my RV-8. I'm just now building the wings and I need to plumb in a fuel return line when I build the tanks. I've read that the fuel line needs to go to the highest point in the tank to prevent fuel from gravity feeding back durring shutdown. Any info on this problem or how you routed yours in the tank would be highly appreciated! Thanks!
I'm not sure why the fuel "running back" would be an issue. Especially if the induction system is above the level of the tanks. I'm putting an Eggenfellner Subaru in my RV-6, and his instructions for plumbing the return lines call for ending them in the tank at the bottom rear side in the second bay outboard. This allows the fuel to return under the fluid level in the tank and cuts down on foaming while allowing the warmer return fuel to mix with the cooler tank fuel before being picked up again by the pump.
I've got a Sube in my -6A. Used unibit to put extra return line holes in cover plate and Earls sealing washers on bulkhead AN fittings- no proseal needed, no leaks. I dump returned fuel into the top of the tanks to de-areate it.
No glitches to date. Think about your EFI fuel system carefully to avoid vapor lock and ensure feed to the high pressure pumps in all flight attitudes. Lots of people get this wrong and the engine becomes silent, bad news in an RV. |
Fuel return line
Bill J Rotary10-RV |
Fuel return line
Fuel Systems for Homebuilt Airplanes
http://www.ellison-fluid-systems.com...uelsystems.htm |
http://www.sdsefi.com/air27.htm http://www.sdsefi.com/rv5.htm Has some photos of header tank, pumps etc. I did not install and special baffling in tanks, not needed with a header tank. Gascolator is probably a laibility with EFI however many inspectors and regulations require one. I have a quick drain one on my header tank which satisfied the inspector here in Canada. |
EFI Fuel filters
Ross, Your website is great. I really learn new stuff every time I visit. Is there an index of all your pages somewhere?
Quick question - did you install a filter between the header tank and the engine? If so, what kind? Also, on your header tank system - do you just have the facet pump on all the time, and the "overflow" from the header tank goes back to the source wing tank? What GPH rating do you run with your pumps? Thanks! |
| All times are GMT -6. The time now is 08:59 PM. |
