Garmin 430W antenna?
What other antennas are required on the 430W besides the Nav (VOR), GPS, & Comm?
:confused: |
NONE
That's all, but the WAAS capable antenna (GA-35) is a little bigger than the old GA-56 GPS antenna. The good thing is that the bolt pattern is the same. The 430 install manual says that you could use the GA-56 antenna (if you had one installed already) but there are limitations on the usage of the 430W.
430w antennas
there's actually a fourth -- glideslope.
You can buy a diplexer that splits the NAV antenna into seperate VOR and glideslope signals for the 430.
ACS sells the Comand CI-507 ![]() |
[quote=bullojm1;168123]You can buy a diplexer that splits the NAV antenna into seperate VOR and glideslope signals for the 430.
ACS sells the Comand CI-507 sure you can. i should have mentioned that. but i was responding from the way i read the question, which i paraphrase "how many antenna connectors are on the back of a 430w?" |
| All times are GMT -6. The time now is 09:21 PM. |
