Questions regarding pull-out-in-instrument-panel-tray-table.
Hello fellow builders, I have some special questions this time.
Being inspired by seeing some airliner cockpits, I am going to install a ? retractable ?in-instrument panel-tray-table? . Well,?...actually it is going to be a replacement for a knee-pad. It will be approx. 6? W X 10? L, when pulled out. When not in use it will slide under/inside the instrument panel. It should allow me to clip A5 size ?Bottlang Airport Manuals?, flight plans, etc. to it and even write on it. To hold the paper, I will steel a spring-clamp from an ordinary clipboard. It will be installed in the center of the instrument panel, under the Throttle/Prop/Mixture- controls (I do not have a sub-panel). For easy viewing and writing and extra clearance from the T/P/M-controls, it will be slightly tilted downwards and therefore be lower than the top of the stick (stick is still in original length). So obviously I have to be careful about stick-clearance. Now to the questions:
Thanks in advance for the input on this. Kind regards, PilotTonny |
| All times are GMT -6. The time now is 04:01 AM. |
