VAF Forums
-   RV Ongoing Maintenance Issues (https://vansairforce.net/community/forumdisplay.php?f=76)
-   -   Prop control cable. (https://vansairforce.net/community/showthread.php?t=22934)
kentb 10-29-2007 11:07 AM
Prop control cable.
I have started noticing that after takeoff that I can't dial back my prop sometimes. It just spins without moving the setting. I need to push the button and pull it back a little and then it work correctly for dialing in and out.
Any suggestions in how to fix this?
Kent
Kahuna 10-29-2007 11:16 AM
Is it possible that in full fwd its binding a little, putting tension on the vernier portion causing it to not catch threads when unwinding?
If you dont put it full fwd, say off an 1/8 inch, does it dial back reliably?
kentb 10-29-2007 04:44 PM
I think so....
I will try it out tonight and report back.
Kent
