Vans Spinner for non RV aircraft?
I have been told that a 13 inch Vans spinner will fit my Murphy Rebel/Elite 360 metal Sensenich 76EM series prop. It has a prop hub thickness of 3.56 inches. However, I know the standard RV Senenich metal prop for the 360 is the 72FM series which has a prop hub thickness of 3.437. That is a difference of about 1/8 inch.
If I order the standard FP 13 SEN spinner kit, I assume then that the front spinner plate would not work, as my prop hub is too thick. If it was smaller, I could add a spacer, but that is not the case. But I also noticed on the Vans website that they list another Sensenich front plate that they say is for "other aircraft". It is part number S-605 SEN. What it doesn't say, thouigh, is what prop hub thickness it allows. I have been talking to a guy at Vans on email about this, but have not been able to get him to understand what I am asking. Does anyone here know exactly what spinner kit I need for the 76EM series prop? Or what is that other S-605 SEN plate for? Any help would be greatly appreciated. Thanks. Walter |
I know it's not the cheapest option.. but have you considered the whole spinner kit from Sensenich.... should be about $400-450 for everything.. and it's all done ready to bolt on...
On my spinner I had to put a few layers of fiberglass on the inside of the spinner to take up the gap for the front plate, so it may work just right in your case. If not you could always build up the spinner near the rear plate to push the spinner forward just a bit. May be worth a try. Cam |
Walter |
Walter |
Most of Van's sub kits, like the spinner kit, are well thought out. The fiberglass may have some pin holes and the directions may... well. You may not even get directions. But in the end Van's stuff works. Buy the spinner kit and jump in. I'm sure it will work for you. You see Van's spinners and wheel pants on all kinds of airplanes. Once you get in the air and if you find yourself in SoCal, I've always liked that plane and would love to check it out. Cam |
So for my next plane, am actually looking at the RV12. Should be a lot more fuel efficient for long trips... So will find out more how good the fabled Vans service is. But was never unhappy with Murhpy, although you have to chase them once in a while to follow up on stuff. I do love my Rebel though. It is a keeper for sure. I am currently upgrading my engine from a 320 to a new Superior 360 with ECI cyls and EI. That's why I am looking for a new spinner. Last time I built my own from a metal kit, but am too lazy to go through that again. Here is a taste of my kind of flying here in BC with my Rebel. http://www.youtube.com/watch?v=E2xgYyXJtM0 Walter |
Walter
Looks like a blast. I've always wanted to fly a plane on floats. There was a bit of that when I lived in Michigan. Not sure of much in SoCal. Instead of waiting for the RV12, take your old 320 and stick it on the front of an RV9. If you can control yourself with the throttle, the RV9 can be a very fuel efficient plane. Cam |
| All times are GMT -6. The time now is 06:42 PM. |
