VAF Forums
-   RV Building Tips/Techniques (https://vansairforce.net/community/forumdisplay.php?f=74)
-   -   Tip: Slow builders and the gascolator doubler (https://vansairforce.net/community/showthread.php?t=2273)
N797RV 07-04-2005 12:22 PM
If your slowbuilding and your using a gascolator, order vans gascolator doubler VA-161 before you put your firewall together, there are three rivets that go into F-601-D-R-1 which I ended up pop riveting (see dwg 13).
Dick
Finish kit canopy
N797RV reserved
