Tach indicator problems
I just switched from LASAR to Slick mags and the RPM indicator shows about 1/2 the actual RPM on the VM1000. The transducer is the correct one for Slick mags P/N 3010005. I have the transducer mounted in the lower vent hole of the Model number 4370 Slick (Non Impulse coupled left mag) Before I purchase another transducer, I wonder if anyone has run into a similar problem?
VM1000 RPM Setup?
The Slick mag has half the number of pulses as the Lasar, you need to change the setting in the VM1000.
Rob Hickman N401RH RV-4 |
I talked to a tech rep today and he explained how to change the jumper in the data processing unit to get the correct readout. Thanks for the responses - problem solved.
| All times are GMT -6. The time now is 06:01 PM. |
