Tip: Keeping my washers straight
I needed a way of organinzing the washers that come in various bags from Van's and hit on the idea of putting them on a tywrap. I put a lable on the tywrap and can also interlink the tywraps with AN-960 on one loop and the AN-960L's hooked together on another loop as in the picture.
Dick Finish kit canopy N797RV reserved |
Dick,
Great idea. Do you use the tywrap that you can undo, or do you use a new one everytime you have to get a washer? Take care, Jim Quote:
If you noticed I just stuck the tab in till is starts to ratchet and leave it. When I need to use one I cut it as close to the ratchet part as I can, take as many washers as I need and stick it back into the ratchet till it ratchets again.
The releaseable tywraps would make more sense but I got a ton of tywraps. Dick |
Dick,
Great idea that I never thought about! I agree with you, as I bought a tub of tywraps last week at HD. Take care, Jim Quote:
Nice tipe, thanks.
| All times are GMT -6. The time now is 07:43 PM. |
