VAF Forums
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   Another E/P mag question (https://vansairforce.net/community/showthread.php?t=22441)
Mike Ice 10-14-2007 02:06 PM
I have an E and a P mag and I want to use an Electronics International Tachometer with them.
Is anyone using an EI tachometer with E/P mags?
Have you discovered any issues? What were they?
Mike
wiring, firewall forward
mike newall 10-17-2007 08:00 AM
The install manual for the E/P Mag shows a couple of ways of using the pulse that comes from them. Either use the P lead with a resistor or use the #6 output ( I think ) from the plug and set up the tacho to count the pulses.
We are using the extra lead into a Dynon 120.
N941WR 10-17-2007 09:59 AM
Mike,
The Dynon EMS D10 has two tach inputs. In my set up, I connected one lead to each P-mag. That way the EMS tach does not drop to zero when I turn off a P-mag.
petehowell 10-17-2007 10:28 AM
Ditto
Did exactly what Bill did, works great.
scard 10-17-2007 12:02 PM
FYI, The Pmag continues to output a tach signal on the tach output even when completely turned off. I have my tach wired to only one pmag tach output and it never drops out on run-up check.
petehowell 10-17-2007 12:37 PM
Emag does stop sending when off
I was RPM "Blinded" until I hooked up the PMag Tach lead when the EMag was powered down.
N941WR 10-17-2007 01:13 PM
Is this true when grounded and power is pulled, as per the Bob K. drawings?
scard 10-17-2007 01:19 PM
Works for me.
