Kelly Landrum okay, Subie 6 is lost...
Just catching up on news after returning from vacation...
Kelly won a couple of awards for craftsmanship with his 6. Sounds like he is okay, but the 6 is a total loss. Says he wants to use the engine again...:( http://www.gazettevirginian.com/arch...0-03-2007.html ![]() ![]() ![]() |
Object?
Since the photos were posted; what is the object mounted in between the hinges on the tip up canopy? Defroster tube?
I believe that's exactly what that is. Since they have real heat, one can run a line anywhere, and that looks like a shroud to spread the heat across the windshield.
Cause of Kelly Landrum's crash - in his own words
As you remember Kelly Landrum damaged his airplane a few month's back. He
writes the following: THIS IS WHAT HAPPENED. Quinti Flyspeed User Error! I entered downwind,reduced power and went to flat pitch by pressing the Flyspeeds up and down arrows simultaneously and deployed full flaps. On short final realizing the airspeed was a little to hot for my short strip, I executed a go-around. That's when the trouble started. Upon powering and pitching up to clear obstacles past the end of my strip, being power line, house and tall trees, in that order, I found myself in deep trouble. Not anticipating doing a go-around, I had failed to program Manual mode and Enter into the Flyspeed controller. Remember them checklist we all are are supposed to use? The flyspeed went course pitch. There was not enough time to clean up flaps and reprogram the Flyspeed all while just barely clearing obstacles. The wings stalled 50' above trees and I had about 1/2 second to slam full forward stick and left rudder in order to ditch and stay upright. From that point on the wrest of that ride was pretty horrific. Came down brushing a tall wooded hedgerow and aimed it between two large tree trunks. The wings took the blunt of the impact dissipating most of the energy just prior to impacting the ground still wings level. I'm almost knocked out, dazed, and Josie was long gone. I've since purchased a new RV6 airframe constructed up to the finish kit by a very meticulous mechanist in my area and the reconstruction is coming along. I'll be using my canopy,turtle deck, tail group, instrument panel and wiring harness, electronics and avionics and the engine, the interior. Will have replace the prop,gearbox, oil cooler, cowl, gear, and pants-fairings. So $30,000.00 and 2 years later,I might be back where I was. At least I have the Piper Colt as my standby. I want to thank everyone from the forum for there off-forum e- mails and concerns about my well being. More later,,, Kelly Best, Tim Naugler RV-6 QB 60500 N251RV reserved Kirkland, WA |
I'm glad to hear Kelly is building/rebuilding again.:) |
Sorry about the plane, but I like the tree trunks dissipating energy part. I now know of three local incidents (not including yours), where landing in trees, or between trees, took the brunt of forces, and the occupants escaped serious injury.
L.Adamson |
Prickly pear cactus
Dissipated energy nicely until she slid into a mesquite tree. The tree is what really damaged the wing....:( Not a test I would like to repeat... gil A |
program Manual mode and Enter into the Flyspeed controller What the heck is a flyspeed controller? I think if I read this right, the next time you use this system, always put things on manual mode for landing. I know when I do a go around, very rare, but when I do, everything happens real quick and the only thing I want to do is put in full power and maybe raise the flaps. In fact I have to say, that's all I think of. I also practice touch and go's with the flaps down, just in case I do a bone head and forget that. On a go around I WILL NOT pull out the check list, so keep it simple and things will work out just fine. |
One more thing, why didn't you anticipate a go around, I think of it every time I land. Always be prepared.
The flyspeed controller is Quinti's system to control pitch of their propeller. It is a computer that needs programming and attention unlike the more simple constant speed controllers we Americans are familiar with. It is a system that adjusts prop rpm automatically based on manifold pressure and in some instances time. There is a procedure to get it into the go around mode. I had one 4 years ago and was quite proficient using it but have forgotten most of it since going with MT. You can educate your self on it by going to Quinti's web site and down loading an owners manual. Beyond that, to Kelly Landrum's credit, he has reported what happened and why. |
| All times are GMT -6. The time now is 08:54 PM. |
