Tip: Paint Respirator
I maintain I would rather work night shift at a convienience store than paint airplanes for a living. But out need recently, I learned a few things, even if I went into it kicking and screaming. The lower cowl on my C-150 needed to be stripped and repainted so a friend introduced me to the finer points of aircraft painting. The first thing he did was take me to the local auto paint supply store where I got an appropriate respirator. This is the disposable respirator with non-replaceable cartridges I bought that is said to be good for 40 hours of use. Believe me, the odor of Jet Glow Matterhorn white is every bit as obnoxious and dangerous as the Akzo epoxy primer I used on my RV-6A. With this respirator on, breathing was unlabored and you couldn't detect the paint fumes. I was pleasantly surprised as to its cost. Relatively cheap lung protection for only $13.50. I will still have my RV professionally painted though.
![]() ![]() Rick Galati RV-6A "Darla" flying RV-8 empennage |
Those charcoal repirators work great for most solvents, but do zilch for isocyanates that are in urethane paints. The molecules are small enough to go right through and don't have a smell, and are very bad for you. FYI.
Steve Zicree |
Rick |
I find that troubling, since all of the literature I've seen says that the odor from isocyanates present in catalyzed urethane is below the level of human detection. So if you're smelling something it's likely other things and not a good indication of isocyanate exposure.
Steve Zicree |
Steve is right on the money here. If you're spraying most urethane paints, a simple respirator does not really do a whole lot of good. The stuff that's really bad (isocyanates) isn't normally detectable with the human nose, and isn't entirely filtered with the passive respirators. Forced air breathing systems are a must when using Urethane paints.
Cheers, Stein. |
some additional info.
anyone interested in what the manufacturer says can read it here. in short there is no way to tell when the filter is saturated with isocyanates but they are good for a while. approx 40 hrs.
"if a painter smells the sweet, fruity pungent odor, of an isocyanate, you have probally already been over exposed." a friend of mine at a high production shop was overexposed once and ended up in the emergency-room for the night. he will not use one for more than a week. http://multimedia.mmm.com/mws/mediaw...66Sld7COrrrrQ- http://solutions.3m.com/wps/portal/3...G.x=5&btnG.y=9 |
Forced air breather
I made one of these. Bought a full face mask on Ebay and 25' of sump pump hose. Worked great.
http://www.sonerai.net/CMS/index.php...id=56&Itemid=1 |
Dishwasher fan
don't forget
Don't forget that you can also absorb chemicals through your skin and eyes, so protecting your lungs alone isn't sufficient.
For my priming I constructed a simple downdraft spray booth that is basically an 8 foot cube. I have a set of bilge blowers for inboard boats on one end to create suction and a set of furnace filters on the other end to filter the incoming air. Airflow is from high to low and the fumes/particles are carried away from me while spraying. There is never mist in the air while I am spraying thanks to this setup. Finally I filter the outgoing air as well through a furnace filter and set of charcoal filters. |
| All times are GMT -6. The time now is 07:34 PM. |
