Water Cooled Lycoming?
I found this while surfing around last night. Interesting design. Burt Rutan tried it on one of his daily flyiers, but removed it for reasons unknown.
http://www.liquidcooledairpower.com/cj-overview.shtml Just thought I would share with you non traditional engine guys. |
Yea they have been around
Last I talked to one of the tech guys, super nice, smart and was nice enough to school me in water cooling, they are working on new cylinders. That was over a year ago. As I have criticised all water cooling, what do you do with the radiators? Cooling drag? They offer the cylinders but what about installation: cowl, radiators..... Price last time they was in the $12,000 range I recall, set of 4, not including radiator'(s). Personally I'm an Air-cooled guy, and I don't see a big advantage. May be on a jump or tow plane that goes up full power and down fast at idle, many times a day, not shock cooling would be a big plus. |
Interesting topic
I've often wondered why more aircraft piston engines are not water-cooled.
I would guess that the thermal stability from liquid cooling could prevent one from barbecuing the cylinders on some muscle climbs as well as to prevent shock cooling on precipitous descents. Assuming they worked reliably, I suspect that the increase in TBO could be significant. |
You would think
Rutan...
https://www.nasm.si.edu/research/aer...t/rutanvoy.htm I think it was a one-off O-200 variant called an IOL-200 gil A |
The Rotax "9XX" series engines have water cooled heads. There are several reasons for this, elimination of detonation when using MOGAS is a big one. One of the side benifits is a toasty warm cabin using the waste heat through a heater core / forced air arrangement in the cabin. Makes for nice flying is zero F weather.
Ram offers a watercooled option on some of its Twin Cessna upgrade packages. They get very few takers.
http://www.ramaircraft.com/Aircraft-...V-Liq-cool.htm |
If you want the whole setup to work well, you need to design it that way from the word go, like the P-51 did with respect to the radiators and drag. In the case of water cooling, that means designing the engine from page one to be high power output, high duty cycle, water cooled, and tight tolerances. While you're at it, turbocharge it, keep the weight down, and design it to run LOP on cheap fuel. Since I know George loves to rail against it (especially when I talk about it :D) I'll say it again just for him - water-cooled turbodiesel! |
As GMC said, this site is old. I came acrossed it it in 2001. It hasn't changed much. Dick emailed me in 2001 after I noticed he'd appeared to endorse the product. He told me to stay away from them. |
The water cooled jugs guys have been floating around for many years but you just don't hear of many/ any people using them. Last updated 2001. Perhaps they are short on cash to perfect them and get all the bugs out. I don't think these will ever catch on in any big way. The current air cooled designs give pretty good service for most people if the CHTs are held below the recommended limits.
I like the Rotax idea of using water cooled heads and aluminum air cooled cylinders. This allows a sealed head casting with no cylinder junction/ gaskets. The heads are where all the heat is. This reduces the rad size considerably as you can see on most 912 installations. CHTs on the 912 rarely exceed 230F so the valve life is excellent and you don't get sticking valves or head cracking on these. The power density of liquid cooled engines is far greater than air cooled engines. As far as the Reno reference goes, remember that the Merlins are ONE HALF the displacement of the Wright R3350s and Dago Red stills holds the fastest race record by over 20mph- 8 minutes of WOT. I don't buy the higher drag theory where a decent radiator setup is used, there are few facts to support this view. Aluminum/ Nikasil cylinders might be a more useful change for the Lycoming. This would reduce weight, cylinder wear, reduce piston clearance and ring end gaps for better oil control, get rid of the old fashioned break-in procedures and use of mineral oil and have far superior heat rejection to steel barrels. The only downside is the base bolted jug design. Might have to be changed to a proper tension stud type retention system like Porsche and Rotax use. This would also stiffen and strengthen the whole assembly. Anyone working on aluminum jugs for the Lycoming? |
| All times are GMT -6. The time now is 08:59 PM. |
