VAF Forums
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   Lightspeed Wire Lengths? (https://vansairforce.net/community/showthread.php?t=21926)
szicree 09-28-2007 05:12 PM
I tried to route my plug wires today and must be missing something. My LSE ignition came with 4 wires: 2 short and 2 long. The shorties are exactly the same length and so are the longies. The shorties are just long enough to reach from cyls 3 and 4 to the left and right coils, respectively. Problem is that 3 and 4 are supposed to be wired to the same coil. What gives?? Can anybody tell me how long the wires are supposed to be cuz I think I simply have the wrong parts.
dan 09-28-2007 06:49 PM
Steve,
The wires shipped with my LSE Plasma II system didn't fit to my satisfaction. Too long, too short, etc. I ordered custom-length wires. Klaus' price on custom wires was pretty good...easy to rationalize at the time.
But I have since taken to making my own wires. I bought bulk MSD 8.5mm wire, terminals, boots, and the little MSD cut/crimp tool. Well worth it. Now I make my own, and obviously the lengths & clockings are dead on. Highly recommended.
AlexPeterson 09-28-2007 07:18 PM
I also had to send back about half of the wires - they really don't work with the lower plugs. I don't think the original ones I got would reach without the baffles. At that time (a year and a half ago) Klaus would exchange them for different lengths. I often wondered how many different customers go the same plug wires...
I will make my own if I need replacements (when).
Alex
szicree 09-29-2007 11:29 AM
I appreciate the advice and making custom length wires would be cool, but I already paid for the LSE which was supposed to include the plug wires. I don't want to contact them until I know it's not my own confusion causing the problem. When I say they don't fit, I don't mean they don't fit well, I mean they don't fit at all. Is this common with this setup or did they give me the wrong parts?
638RS 09-29-2007 12:22 PM
Where to buy
Dan, Where did you buy your wire and boots? A Google search turned up wire in 25ft and 50ft lengths or and completed wires of different sizes.
dan 09-30-2007 01:52 AM
It's been a while, but I'm pretty sure I got it from Summit Racing.
Capflyer 09-30-2007 05:38 AM
I went to my local speed shop 1/2 mile from my airport and found all kinds of MSD stuff and kits. I ended up purchasing very inexpensively a boot kit that came with the tool to install them and a few feet off a master roll of 8.5mm wire.
I also found 37deg AN fittings there!
Mike R.
gmcjetpilot 12-27-2007 04:23 AM
What type of wire & boots?
What type of wire?
I see the hot rod catalog has three different wire cores:
Spiral
Carbon/Graphite
Stainless (racing only?)
I also see you can get 8, 8.5 and up to 11 mm
Boot wise there are two: HEI and than "point or cap type" boots (which come in straight, 90 and 135).
Does the coil take a HEI type boot or different?
Edit: Thanks Radomir!
Radomir 12-27-2007 08:02 AM
The wire is MSD Superconductor 8.5mm
Gsuit 02-10-2008 07:27 PM
Plug Wire Resistance
Sorry for the very late addition to this post - but I had an issue turn up tonight.
I too have LSE plug wires that are too short. But I've been using them during my "First Start" and "Subsequent Start" troubleshooting. Tonight I made new wires from wire and terminals I bought at Summit Racing. The new stuff is MSD 8.5mm SuperConductor wire, just like the ones that came with my LSE.
I made them to look just like the originals from Klaus... same length center conductor sticking into the terminal and all. My new wires are slightly longer than the originals - maybe 30% longer on the #2 wire.
When I compared the impendence with the original wires I got a surprise. The original #1 wire was ~67 Ohms. The new #1 was ~6K Ohms! This seems really bad... but I do know that in most automobiles, higher impedance is better because it cuts down on radio noise.:confused:
My questions are:
- what is the correct range of impedance for an LSE Plasma III?
- is there some secret 'gotcha' to crimping terminals on to plug wires?
