GNS-430 Installation Manual
I'm looking for Garmin GNS-430 Installation Manual.
Does anyone has it? I couldn't find it over the web... |
OK
It's about 5 Mb so please let me know it arrived... gil A |
Its on Garmins website
At least it was when I downloaded it from there.
Frank |
It isn't anymore at garmin website |
install manual
hello, i'm also looking for the install manual of the GNS 430.
could you please email it to me quickly? Thanks a lot. St?phane - French Polynesia |
I'm wondering if the OP is in need of a firmware upgrade on either their 430 or AP. CRS should work if you have a valid serial input; it should not require an active navigation leg. Another possibility is transmission "speed" (a bit of a misnomer, since my understanding is that "Fast" really just drops some of the sentences from each burst), which may only provide full functionality at one speed setting and may require both units to be "matched" (have the same speed setting on both units). I'm speaking generically since I have a different AP/Radio (GNS 480 / TruTrak), but had similar issues originally. In my case it required both a software upgrade and reconfiguration to get them to play nice together.
| All times are GMT -6. The time now is 09:15 PM. |
