Catto 3 blades performance with O320 on a 7A
I intend to have a Catto 3 blades on my 7A, with a O320. I have no clue on which pitch to order, I didn't even start to discuss with Craig at Catto. For those with similar configuration, can you please give me performances acheived (top speed, speed at 75%, climb solo and gross weight) for which pitch.
Thanks in advance. |
Talk to Craig. He is the expert on which prop to use on any given plane, engine and mission configuration. I told him I just wanted my plane to be 2 kts. faster than my hanger mates RV-7 :-)
Steve Eberhart RV-7A, just riveted on the last major piece of aluminum. It really looks like an airplane now. |
I have an IO360 using a 3 blade Catto 66x76.
Originally, I suspected an overpitch but after engine break-in and adding the fairings along with airframe cleanup, Craig was right on the money. I asked him to pitch to achieve Van's specs. I have found the prop to be draggy in that with a headwind, I lose rpms. Otherwise, I'm very happy with the prop. Tell Craig what you want in performance and he will deliver. |
During 3 & 4 way speed tests, same throttle setting, depending on the headwinds encountered on that leg, I would see a loss in rpm of about 20-50rpm. RPMs would recover once turning back into a neutral or tailwind situation. RPMs also suffered when non-faired. |
I still don't get it
None of the conventional laws of physics explain why the stabilized full throttle rpm at full throttle in level flight should depend on the wind. If this is truly a repeatable effect, you should contact an aeronautical engineering school and ask them if they want to investigate it - there could be a Nobel Prize hiding in there somewhere. |
| All times are GMT -6. The time now is 06:33 PM. |
