New 105hp diesel engine, Raptor Turbo Diesel
A quick search didn't yield any mention of it, hope I'm right. Perhaps something for the -12?
http://www.raptorturbodiesel.com/index.html
Horsepower 105 HP (78 kW) @ 2500 Prop RPM, 2875 Engine RPM Continous power
Configuration Turbo diesel, 4 cylinder in-line, 4 stroke cycle, Liquid cooled, Propellor speed reduced
Diesel Fuel Injection
Raptor designed common rail fuel contoller, 1800 bar (26100 psi) operating pressure
Propellor Speed Reduction Link plate style reduction unit, 1.148:1 Ratio
Diesel #2 (autodiesel), Jet A, JP-8, most biodiesel. Different approved fuels may be mixed in tank in any proportions.
Dimensions
Length 22.50 inches 571.5 mm
Width 22.25 inches 565.2 mm
Height
16.50 inches 419.1 mm
Bore
2.972 inches 75.5 mm
Stroke
3.327 inches 84.5 mm
Displacement
92 cubic inches ( 1.55 Liter )
Weight
179 lbs 81 kg (see separate heading)
It's certainly something for fans of alternative engines to examine and ponder, but I'm not too sure about the qualities of this design. It comes with practically none of the simplified features that Deltahawk have incorporated. It's dead without electricity, it's not mechanically simpler (perhaps more complex!) than a Rotax 914, it's got a reduction drive and it's a flat inline. Correct me if I'm wrong, but if all the power pulses are in the same direction, won't it be vibrating a lot?
The quoted weight doesn't seem too bad at first, but installed it might be 30 lbs heavier than 914.
While I love reading about new designs, I think this one is off the mark. A four stroke diesel will probably get better mileage, here in Euroland Jet A1 comes with a price advantage too. But if it's more complex, electric reliant, heavier and perhaps comes with a bigger price tag...it's hard to look past a Rotax.
