VAF Forums
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   E-mag fixed (https://vansairforce.net/community/showthread.php?t=21624)
videobobk 09-19-2007 07:31 PM
E-mag fixed
Just gotta praise the guys at E-Mag a little. We had some occasional roughness and high EGT's with an E-Mag. Pulled it off Sunday evening (<15 minutes,) sent it off Monday, got it back fixed today (Wednesday,) installed it this afternoon (about an hour) and flew with no symptoms.
Friends, that is service. They turned it around in a couple of hours. While I don't like the fact I had a problem, I can live with it when I know they care about keeping you flying. I happy with the performance of the E-Mag also.
Bob Kelly
Yukon 09-19-2007 08:25 PM
Bob Kelly
What was the problem?
gasman 09-20-2007 02:24 AM
It must be good to know that they will ship to any place that your stranded, and only in three days.
videobobk 09-20-2007 07:00 AM
Cold solder joint between the circuit board and coil. Something QC should have caught, and probably will from now on.
Bob
Rick RV-4 09-20-2007 09:11 AM
Gasman,
I'm assuming you're being cynical, but I've been stranded before due to supposedly "reliable" parts (like magnetos) before, and it took a LOT longer to get the parts I needed back. Personally, I think a two-hour turn time is pretty impressive.
Rick
